Question about Tamron Zoom Telephoto AF 70-300mm f/4.0-5.6 LD Macro Autofocus Lens for Canon EOS
I have a Tamron 70-300 lens that is stuck at 70mm. Can I take it apart?
Barrel turns but no effect.
2 Suggested Answers
kleinohad2
  • 19 Answers
SOURCE: if you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Posted on Jul 10, 2012
Tamron 70-300 TELE-MACRO is stuck. It only moves a little around 200 mm. A fix?
Professional repair, you can't take it apart yourself. There are too many screws, locking rings, shims and lens elements that all have to in the right place to few thousands of an inch. Then it all has to be done in a dust free environment.
Feb 20, 2018 | Tamron Cameras
I have just purchased a Tamron 35-70 3.5 CF MACRO BBar MC Nikon fit lens. Are there any special settings/requirements when using the lens for macro photography. Thanks.
This is a macro lens, and I can't find it has an auto focus nor can I find if it has a chip, or even any electrical connection. The sharpness though should be good.
When you are using a non chip lens on a Nikon, you only can use it in manual. So you have to put the main dial to M. Then you have to focus manual and just take a shot. the result will be to dark or to light, unless you already knew hoe much light you have and dialled the aperture and shutter time in correct.
For macro you want a large aperture number, to have as much sharpness (large depth of field) so the best thing is to choose f 8 or 11 and turn down the speed till you have a good light picture.
I found a forum about this lens, but they did not say a thing about the specs.
Tamron Adaptall 2 35 70mm F3 5 CF Macro 17A
Check some results here:
Tamron 35 70mm 3 5 17A on the GH2
Jan 23, 2015 | Nikon Cameras
Where would I find the serial number on a Tamron 90mm Canon macro lens?
all of my Tamron lenses have the serial number on the barrel of the lens right next to the "Made in Japan" label. When the lens is in the camera the MIJ label is on the bottom side. I hope that helps with your lens
Aug 31, 2014 | Tamron Cameras
Problems using Nikkor AF 35-70mm F3.3-4.5 with Nikon D80?
The sensor on the D80 is smaller than a piece of 35mm film. This means the camera will only use the center portion of the image cast by the lens. This reduces the angle of view, effectively increasing the focal length. The 35-70mm will give you an angle of view similar to a 52-105mm lens on a film camera. Likewise the 70-210mm lens will give you an angle of view similar to a 105-315mm lens.
Apr 18, 2012 | Nikon Af Nikkor 35-70mm F3.3-4.5 Camera
I have a minolta MD lens 35-70mm f3.5 that is stuck at 70mm. how do i get it unstuck?
Hi!
Is your lens having a "macro 1:4 - 1:7" green sign near the "70"? If it does it may be stuck in the macro position... ? To put it back into the normal "35-70" zooming position just press the little black and greenish button on the lens, turning the zoom anti-clockwise.
Well... i'm Italian and tonight my english is particularly stuck.. But I hope this could help you!
Let me know, cheers :)
Emi
Feb 02, 2011 | Cameras
I broke the uv filter on my Tamron 18-270 lens. The tiny glass fragments appear to have gone behind the first lens. There is also a crack in the thread where you screw in the filter. A tech quoted on a...
$450 for a complete repair? Online, the lens doesn't cost that much! Have you contacted Tamron? Their lens repair service is much more reasonable than that.
Jan 20, 2011 | Cameras
My 24-70mm f2.8 Sigma lens will not autofocus. It
Hi
If it is a DF lens thay are to ways to set the AF
first is to push the A/M button on the rear barell
to AF and then slide or pull the manual focussnig
ring you will a mark on the barrel with AF or manual
Oct 09, 2009 | Sigma 24-70mm f/2.8 EX for Canon
Tamron teleconverter 2x AFs compatibility.
When using a TC, as the perceived focal length increases and the aperture falls off, AF struggles to work except in very bright light.
Jun 09, 2017 | Tamron Autofocus 2x Teleconverter Lens for...
Lens will not change range. Something came loose inside
Are you trying to turn the barrel of the lens when it is in the Macro Button on ?
Sep 05, 2008 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
Tamron Zoom Telephoto AF 70-300mm f/4.0-5.6 LD Macro Autofocus Lens for Canon EOS Logo
37 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
