GE ghwn5250dws need repair manual
Clothes stuck under agiator
3 Suggested Answers
  • 132 Answers
SOURCE: My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Posted on Jul 15, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have change stuck under basket or agiator, how
Hello, welcome to FixYa.
I will start by saying your post indicates it is a Whirlpool washer, however if you could post the complete model number and the approximate age I can speak directly about your's instead of generalizing.
Hopefully you can appreciate there are many differences even within the Whirlpool brand. I'll need to clarify the model number before detailing much of course. I'll need to watch for your reply before moving forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Jun 01, 2011
Fabric softener not dispensing
It might be clogged, try putting some hot water (not boiling hot tap water is fine) to in clog it. Look up the manual and see if the dispenser can be removed for cleaning.
Dec 24, 2014 | GE Adora 3.9 cu. ft. Top Load Washer in...
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
GE Adora GHWN5250D0WS beeps twice, wont start
Sounds like the lid switch is broken if you need more help please let me know
Mar 28, 2014 | GE Adora 3.9 cu. ft. Top Load Washer in...
Washer makes loud clanging noise when in use
Does it make noise all the time or just in agitate/spin mode?
Oct 13, 2012 | GE Adora 3.9 cu. ft. Top Load Washer in...
My problem is the agiator tears my clothes what is wrong this does not happen everytime just sometime and ravels towels?
Perhaps you need to remove the agitator and look under it for objects that do not belong.
In the past I have found items of clothing and such.
Cabrio service manual
Jan 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Grease coming out after spin into washing
http://www.washerhelp.co.uk/diy-repair-help.html
If your statement is referring to having grease
being left on clothing during washing; It could be the grease seal located on the shaft that drives the "agitator" which is the paddle arrangement in the machine tub.
You can check this by removing the screw or bolt that holds the "agitator" in place.
You do this with the machine filled with water with no soap and no apparel [clothing sheet towels] in the tub at this time.
With the machine filled with water; turn it on and allow it to "agiate" for about a half minute.
That should cause the agitator to free it'self from the shaft.
Turn the machine offf then lift the agiator from the tub, then place the control in the drain/spin position to remove the waer.
After the water is pumped from the machine you can inspect the bottom of the tub for lubricant.
If it is present there are a couple of options, first if it is a fairly new machine and or if you have a manitanance agreement then call them for repairs if it is an old machine without a repair agreement then you might want to consider replacement.
As a severe warning do not place any body parts in the machine while it is operating!
If the lubricant is under the machine possibly you recently had it repaired or lubricated with an exceessive amount applied also again !if it is an older or well used machine particulary it consistently being overloaded , that could cause tranmission seal failure
May 05, 2010 | Speed Queen SWT920 Washer
The washer aggitator is very lose . moves up and down about 1-2 ins.
If there is a bolt to loosen under the dispenser remove it and see if you can pull up the entire agiator. If so, the drive hub is the problem and needs replacement.
May 03, 2010 | GE WVSR1060A Top Load Washer
A TABLECLOTH HAS DISSINTAGRATED IN THE WASHING MACHINE ZWF 1210W AND THE MACHINE WILL ONLY EMPTY VERY SLOWLY I HAVE EMPTIED A LARGE AMOUNT OF THE DISINTAGRATED COTTON FROM THE OUTLET IMPELLER CHAMBER BUT...
A lot of the table cloth is stuck under the agiator, you can pull it off and remove the table cloth material from the bottom, this is keeping the aigator from turning and allowing the water to drain, make sure you unplug the washing machine while you work on it.
Feb 13, 2010 | Zanussi ZEBF250W Bottom Freezer...
THANKS
Jul 15, 2009 | Washing Machines
Bowl spiner
What is a bowl spinner, my washer is only 3 years old and seems to not aggitate any more. The light come on complaining of either the water is too hot or the bowl is unbalanced. puting my clothes on the cold cycle and balancing the load does not do any good. the wash and spin cycle will run its cource and I get dirty clothes from it!@!#@#$$@@!!!*^!
Nov 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
