Question about Nortel Lands Phones
How to make phone ring for two incoming lines
I have a Nortel Norstar M7208. I have two different lines that ring through the phone but currently, the phone only rings for one of the lines. How do I get it to ring for both lines?
    Scholar:
  • 277 Answers
This is tech side programming known as Configuration, clients usually call in a tech/vendor for this.
You need to find out the password and know how to navigate the system programming, do F**266344 and enter the password.
Navigate to Sets, add line in question , assign ring type.
Posted on Dec 11, 2012
  • 31 Answers
SOURCE: Programming a phone to pick up calls
I need more information. When calls come in, does the triangles appear on the phones you want to pick up? Do you have all the lines on the phones? Is sounds like you want only the "ringing sound" to happen on your phone, but have it appear on the others. Is this correct??
Posted on May 23, 2007
  • 32 Answers
SOURCE: My Nortel Meridian M2008 phone will not ring
it may be turned down to low.press the program key and use the scroll bar below the keypad to find your option...hopes this helps
Posted on Dec 20, 2008
consultel1
  • 860 Answers
SOURCE: How do I retrieve recent incoming calls
If you have call log set up you can access the log log by pressing feature 812. To program that feature as a one touch button press feature *3, press the button you what to be call log and enter feature 812
Posted on Mar 27, 2009
SOURCE: Doesnt ring
My BT Meridian compact does not ring after it powered down in a thunder storm. The lines flash and can be answered as normal just no ringing sound
Posted on Jun 16, 2009
consultel1
  • 860 Answers
SOURCE: Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Posted on Sep 21, 2009
What could cause norstar m7208 phone to not receive incoming calls
If you have lines appearing on your phone and they don't ring you need to program lines to ring. This type of programming is done from a M7310 phone. Page 323 of this manual shows how to program this on a NorthStar MICS Ver 6 phone system.
http://pdf.textfiles.com/manuals/TELECOM-F-R/Nortel%20MICS%20System%20Installer%20Guide%206.1.pdf
Enter the programming mode : Feature **266344
Password:266344
You will have 4 programming buttons on your phone, normally the 2 top left and 2 top right of the 2 vertical rows.
top left = move up one level
lower left = back
top right = select
lower right = next
once you enter the programming mode press next to "Terminals and Sets"
press select
enter your extension number
press select
press next to "Line Access"
press select
press next to "Line Assignment"
press select
use the next key to go to the line you want and use the soft-key below the display to change it from "Appear" to "Appear and Ring"
May 05, 2015 | Nortel Norstar M7208 Telephone
What does dstnct rng mean on nortel phone
Different rings for internal (intercom) vs outside (central-office) calls.
Jul 10, 2014 | NorStar M7208 Corded Phone
What does aux ringer mean on nortel phone
There is a contact closure output on the common equipment ("KSU") which can activate an external signal on a ringing line.
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
Incoming calls briefly ring once then automatically kick over to answering machine. I cannot get any incoming calls
Are you using norstar voicemail system?
If you are and know how to get into the admin programming of it, then you go to the line programming and select the number of rings before the vmail system answers.
set the rings to "3", then the lines should ring 3 times on your phone, then on the 4th ring the vmail system will answer
Jun 26, 2009 | NorStar M7208 Corded Phone
Mar 27, 2009 | Nortel Meridian M7208 Corded Phone
My phone, a meridian M7208, does not ring incoming calls
following a power failure, the only phone that rings is the one in reception. light still flashes but no ringing from any other phones
Feb 16, 2009 | Nortel Meridian M7208 Corded Phone
Lands Phones Logo
164 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
