Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Looking to buy the red pin to set the sign timer
There are two pins on the timer one is green and one is red and when i took the red pin out to set time on my sign and it broke so i need the red pin to replace
  • Intermatic Master
  • 5,089 Answers
1) Timer is not identified.
Question posted under Intermatic T100 series which has metal trippers, and not green and red.
2) Copy following links to help identify timer:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Tork-timers-and-manuals.html
http://waterheatertimer.org/Paragon-timers-and-manuals.html
3) Add a comment Dec 2012 and describe timer in detail. Or attach a photo of the timer for possible identification.
Posted on Dec 10, 2012
  • 10865 Answers
SOURCE: Can't figure out how to set Intermatic timer 111c up to nightlight
Hello. I can help you with this times.
Step one - insert the pins at the times you want the night light to come on and go off. The green pins will turn on the night light and the red pins will turn it off. If you just want one on time and one off time just use one pin of each color.
After you have the pins inserted, set the correct time on the timer and plug it into an outlet that is always on [not one that is controlled by a wall switch].
The override switch will turn the device off if it is on, but just one time. As the next time it turns on it will once again be controlled by the times.
If ou want the night light to come on and off in the evening and again in the morninng, use two green pins and two red pins. Push in a green pin at each time where you want the night light to come on and push in a red pin at each time you want it to go off.
Get back if you need additional clarification.
Posted on Jun 02, 2009
jmgldsmth
  • 1869 Answers
SOURCE: pool timer not turning pump on
the timer motor brushes are worn out
Posted on May 28, 2009
rogrrabbit
  • 986 Answers
SOURCE: I have an intermatic T101 and the trip pin broke
You may be able to rig it up. They dont sell parts for these. If you can jury rig it just get a new one
Posted on Sep 12, 2009
SOURCE: Need to purchase pins to place in the small daily timer of the ti
go to intermatic site
www.intermatic an search for irrigation timers. scroll to bottom of page and you'll see whats listed below
* Includes rain sensor input terminals- rain sensor not supplied.
** Includes 24 volt - 20 VA transformer.
For additional trippers (12 per pack), order No. 156T1950A.
For additional skipper pins (14 per pack), order No. 156T1954A.
Posted on Oct 20, 2009
SOURCE: intermatic Time All ,model TB111. lost plastic pin
I have the pieces for an Intermatic Time All, model TB111 because mine stopped working. I don't know how to get in touch with you.
Posted on Feb 06, 2010
I have red pins and white pins; which is for on and which for OFF?
install pins and manually rotate timer dial and see when light tuns on.
http://waterheatertimer.org/How-to-set-timers.html
How to set timers
Feb 26, 2016 | Hardware & Accessories
How do I insert the green and red pins into a timer, they keep falling off
What timer do you have?
What is a solar?
Add a comment and describe timer in detail.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TN
Some timers have integral trippers that are not removed.
Aug 24, 2012 | Hardware & Accessories
I have a basic timer with no pins. Can't figure out how to use it.
You posted under GE 15004 timer.
To make sure we are discussing same timer, see image of product at Jasco:
http://www.jascoproducts.com/products/pc/GE-24-Hour-Plug-In-Timer-86p169.htm
If this is not your timer, then add a comment.
I do not have a manual for this timer.
Jasco has not posted manual for 15004 timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15004
Looking at timer, it appears as if the following instructions apply.
Since you have the product and instruction sheet, add a comment if your knowledge of the details varies: Your contribution to the fixya community is helpful to others.
To set timer:
Rotate dial clockwise until current time lines up with pointer.
Move red and green pins to hours you want timer to turn on-off.
Pins are non-removable.
Dec 20, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Where can i bur additional TN111 red and green pins
Go to this website and search for intermatic TN111C green pins.......
http://www.electronicplus.com
they sell for about 75 cents
Sep 13, 2010 | Intermatic TN111C - Heavy Duty Lamp and...
Our timer has a red pin and green pin how do we set the timer? We cant find the instructions from last year we used it for our Christmas lights. It is just a small timer.
Put red pin in one spot put green pin in another pluged lights into timer continued to turn until lights came on and went off
Nov 19, 2009 | Electronics - Others
How to set a timer to come on at 8am off at 8pm
you set the arrow to the correct time. You then pull the green and red plastic pointers up and out of the device and push them back in at the times you want it to activate. I believe green is off and red on but I may be backwards on this. Some come with multiple on and off pins you would simply remove these or pull them up so they do not trigger the timer
Oct 29, 2009 | Intermatic 10 Amp Mechanical Indoor Timer
Jun 02, 2009 | Intermatic & Lighted Dial Timer
Scheme for the VGA Cable of Acer AL1511eb
You will have to buy a 13 Pin Din Male Connector cord. Use the break-down below to help with reconfiguring.
Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 N/C Not connected Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 +5 V +5 V DC Pin 10 GND Ground (VSync, DDC) Pin 11 N/C Not connected Pin 12 SDA I²C data Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 SCL I²C clock
Nov 24, 2008 | Computers & Internet
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
