Question about Epson Office Equipment & Supplies
Image bounces back to laptop from Epson projector. I manually toggle back to projector, then it bounces back on its own. Sometimes immediately...sometimes after a few minutes. I have to keep hitting the key to switch it back to the projector. Any suggestions?
    New Friend:
It is necessary for you to make sure that the native resolution of the projector match the laptop's native resolution. If after changing the resolution, the image is still bounces back to laptop then you will probably need to completely disable your laptop display so the image is shown only on the projection device.
Posted on Dec 12, 2012
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Projector and Dell Laptop
make sure the resolution on the projector matches the resolution from the source. you may need to auto source, or reset to factory default.
Posted on Sep 03, 2009
Hi. My Dell Latitude E6410 does not recognize a Epson Projector, model EMP-7800. How can I solve the problem?
Hi
you must tell the laptop to display out on the projector,
how to do that?! you must toggle the display path
Generally, there is button ( with Fn keys ) have dusplay screen sample on it, use it with Fn to toggle the display
Display have 3 modes:
  1. laptop screen
  2. outside LCD projector or monitor,
  3. or bith 1 + 2
you can press the keys 3 times ( at maximum ) to have the display on both laptop screen and projector
Good Luck
May 13, 2011 | Dell Latitude E6410 Laptop
Projector has image on screen but cannot get connectrion to laptop to project pwerpoint
Be sure you have the right input selected. You might try Auto Search. Then toggle the laptop using the F8 or proper function key to display the output to the projector or in both places. Sometimes the laptop must be hooked up to the projector before the laptop is turned on. Hope one of these works.
Feb 09, 2011 | InFocus Office Equipment & Supplies
Cannot get the image to project from VGA port from my HP laptop
You have function key (FN) that you need to hold down while pressing the icon screen key or CRT key depending on the model of your laptop at the same time. If you toggle this 3 times each provides a no image to the projector or an image to the laptop screen or projector and laptop image.
Jun 05, 2010 | Dell 1409X DLP Projector
When linked to my laptop, the Sanyo PDG-DSU21N Projector will not project on the screen. It keeps searching for computer/ s video...etc. When I click on Menu, I do not have an option to select...
You need to send your laptop signal to your projector by pressing the FN key and the key that says CRT/or an icon of a screen (this is located at the top of your keyboard). 3l toggles will give you different images. i.e. projector image only, projector image and laptop image or just the laptop and not projector image.
Jun 02, 2010 | Sanyo PDG-DSU21N Projector
Enable graphics port for projector image
Once you get the cables attched in the correct order RCB cable from the vga port on the laptop to the projector and the audio cable connected. Use function key combination Fn + F7 to toggle through the video outputs. This toggles the video card to send the signal to the different sources.
If you need to zoom or magnify the image, the combination for that is Fn + F10. This actually changes the screens resolution, it will toggle through all the settings.
Oct 20, 2009 | Sony Vaio VGN-SZ640N05 PC Notebook
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
Computer Screen Image too small when shown through LCD Projector
You may have to setup the EXTERNAL resoloution for a bigger picture than can generally display on the lappy's screen... there is uaually a setting for the dual display setup... Right Click desktop and click Properties, the video settings can be acessed from there... Also ensure ya have the latest most up-to-date drivers for ya lappy's Video too.
Feb 08, 2008 | Acer Aspire 5610-4648 Notebook
Hooking projector
You will probably need a standard VGA cable. The ends look like the connection for a monitor. Take a look if you don't know what I'm talking about: http://en.wikipedia.org/wiki/VGA_connector
There should be a port on your laptop and one on the projector. After it's hooked up you might have to toggle between the projection settings or select the correct source on the projector. Normally, there is a source or input button on the projector. If the picture isn't showing up on the projector but is on the laptop or vice versa, you'll need to toggle between settings. On my dell, it is fn (function) and the F8 key but sometimes it's the F7 key or some other F? key, just look for the LCD/CRT on the function button or the picture of a monitor looking thing. This is only if you don't see the image from the projector. Hope this helps you out!
Nov 09, 2007 | Compaq Presario 1200 Notebook
Double Image
It's may be the video cable from the PC. I had the exact same problem with my Epson projector today. Treat y
Oct 06, 2006 | Epson PowerLite 5000 Multimedia Projector
227 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
