Question about Sony MHC-G100 Shelf System
Standby led sony MHC-GNZ888D blinking (intermitent)
The standby led was blinking, and I cannot switch on the unit.
But it is intermittent, sometime the unit working properly and suddenly switch off and standby led blinking again.
Which the part was problem?
  • 4 more comments
  • patno72 Jan 14, 2009
    Dear Nuwan chinth, thanks for your answer.
    This is helpful, but it is so global answer : )
    Could you narrow the problem ?
    If the problem on the power supply or power amp, which the component was broke ?
    Any body,s suggestion are welcome
  • patno72 Jan 15, 2009
    I have checked the connection , and no problem.
    When problem occured , I hear sound like mousquito sing at power supply part.
    But when the unit working properly, the sound (mousquito sing) is mute
    is it problem problem caused the condesator or ic or transistor or zener diode ?
    Thanks
    Dear Nuwan, Thanks for your suggestion.
    Where is the position of the relay, on power supply board or on Power amp board ?
    Thanks
    Thanks for your fast respone.
    A little question : on the manual guide said, if we close the ventilasi of the fan, the standby led will blinking.
    What is the sensor on the unit to detect it ? Is this temp sensor or light sensor or other ?
  • patno72 Jan 16, 2009
    I'll try to send the manual to you.
    I will explore the unit to check the relay, and inform you for the result
    Thx
  • patno72 Jan 21, 2009
    I have explored the unit.
    But I did'nt find the relay.
    any suggestion ?
    thx
    New Friend:
  • 111 Answers
Power amp.or power supply printed circuit board.
nuwan.
Posted on Jan 13, 2009
  • 2 more comments
  • nuwan chinthaka
    nuwan chinthaka Jan 15, 2009
    first of all check the power supply for loose connections.
    then try others.
    i will help you.
    nuwan.
  • nuwan chinthaka
    ok,please observe one of relay swiched when the problem occured.it will happence simultanionsly.it is speaker protection or stanby relay.please tell which relay turnd on .stanby relay is closed to power suplly circuit and anotherone is closed to speaker connector.
    nuwan.
  • nuwan chinthaka
    please find the relay yourself.power relay can place power supply board and speker protection board can place closed to power amp board or bouth can placed same board the power amp board.
    nuwan.....
  • nuwan chinthaka
    IT SHOULD BE THERMISTER.closed to fan or heatsink.(2pin device).
    IF YOU HAVE ANY OF MANUAL PLEASE EMAIL IT TO ME.
    roshanw@ccl.lk
    nuwan.
I have an Alba 32947HD TV. It was totally dead. The PSU board was faulty. I have replaced the PSU & now the standby light flashes - sometimes slowly, sometimes faster. There is no sound & no pictur
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 30, 2017 | Alba Televison & Video
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Intermittent Blink code 4
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.....
Sep 01, 2016 | Televison & Video
My tv continues to blink
What is the brand name of your TV? These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Jul 23, 2016 | Televison & Video
My TV lost the picture. Pushing on the indicates no back lighting. The Standby LED was giving a single and intermittent flash but now nothing. All PS voltages are present.
Single flash indicates main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 03, 2015 | Sony BRAVIA KDL-46V3000 Television
Sony KDL-52W4100 standby light blinks 13 times after being switched on. The lower part of the screen briefly lights up then the unit standby light starts flashing
Nov 28, 2014 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Why won't the tv come on, just get intermittent flashing red standby light?
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the unit and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sep 18, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
I have LG 32LC46-ZC TV. It suddenly stopped working, no picture, no sound. The LED blinks 5 times after turning on, but nothing else. Any suggestions?
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | LG Televison & Video
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Sony gnz888d stanby bulb is blinking
Check the back of the stereo to make sure none of the speaker wires are shorted, if okay! it is one or two audio output ic's that are shorted causing the protection circuits to activate to prevent further damage.
May 01, 2012 | Sony Audio Players & Recorders
1,001 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
