Question about Hasbro Zoombox DVD Entertainment Projector
Zoombox by tiger won't play dvd
Dvd player spins but, says no dvd
Tip
Player reading invalid disc and disc is not spinning
My dual screen dvd player was reading invalid disc and disc was not spinning. Took player completely apart and white gears had dirt in them. This was preventing the player from spinning. Used dust remover and cleaned the whole inside and now it works great.
on Sep 01, 2008 | Durabrand DUR7 Portable DVD Player
Dvd won't spin
The unit could be new/defective----take it back if new and exchange it---if do that check the new unit before leaving store.
Nov 03, 2012 | Supersonic Televison & Video
Why my portable dvd playing won't play when i put a dvd dics in?
If it takes and accepts the disc but will not play it is either a mechanical issue (table not spinning the disc) or if not reading disc it is likely a dirty or bad optical pickup in the unit---
Nov 03, 2012 | Televison & Video
The DVD keep spinning but won't play
see the next steps and fix it. God bless you
Clean a DVD disc:
  1. Hold the disc by its central hub and outside edge.
  2. Blow dust from the bottom surface with a can of compressed air.
  3. Clean dirt and fingerprints from the bottom surface with a lint-free cloth dampened with CD/DVD-cleaning fluid or denatured alcohol, wiping from the center outward.
  4. Clean the objective lens:
  5. Remove the housing and lift the hold-down clamp to expose the lens.
  6. Remove dust with canned air or soft brush. If needed, use a foam swab or a camera-lens tissue dampened with lens fluid.
Oct 03, 2012 | Mintek MDP-1070
Does not spin dvd
Sometimes the brushless motor driver circuit fails. Rarely does the motor itself go bad. On some models, if the the laser diode is too weak to read the disc, the player will not bother to spin it. It won't spin so a lens cleaner disc won't work You can try to take it apart and clean the tiny lens. Don't use alcohol. Windex and a Q-tip works great to remove grease and dirt. Don't buff it hard. Just wipe lightly a few times and look at it at an angle to make sure it is shiny, not hazy. Almost all of these are not an economically viable repair. If cleaning the lens does not help, you are looking at another portable player.
Sep 02, 2012 | kawasaki PVS-10921 Portable DVD Player
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Dvd's won't play on my sony dvd player
If making a noise the issue could be in the mechanism and or the motor that spins the disc---unless it is a real expensive and fairly new unit it would be better to just replace it.
Apr 16, 2012 | Sony Televison & Video
My Funai WV805 DVD player quit playing DVDs
Hello
If the DVD do not spins inside the playere, this type of fault can occur. Open the top cover of the player and insert a dvd. See whether it spins inside or not. If not, replace the motor that spins the disc inside. This motor is known as Sled motor.
If disc spins inide and the player do not read or play it, replace the Laser Pickup Unit. It is faulty.
Mar 01, 2012 | Televison & Video
Hasbro Zoombox DVD Entertainment Projector Logo
63 people viewed this question
Top Hasbro Audio Players & Recorders Experts
Richard Lilja
Richard Lilja
Tom Chichester
Are you a Hasbro Audio Player and Recorder Expert? Answer questions, earn points and help others
