Question about Intel Motherboard
Computer Won't Power On
I've been having a number of issues getting my computer to power on.
The short version is that when I go to power it on, the fans/lights kick on for about 2-5 seconds, and then it powers down and restarts the process again.  It will loop like this endlessly unless manually powered down during the breif window when it has power.  At no time during this does the monitor react at all (no bios, nothing, it's like the comp is off)
There are a great deal more details though.  I have had this issue previously, and replaced my psu at that time to correct it.  Interestingly, there was a noticable preformance boost after replacing the psu, and it seemed to work fine for about 2 more months.  Gradually though, the problem has returned.  A few weeks ago, when restarting the computer it started doing that same 'loop' again, but after a few tries it came on and seemed to work normally.  After restarting it today though, it won't get past it.
Additionally, and possibly related, I've had microphone issues in the past with this system, before the first time this restarting issue has occured.  A loud buzz when speaking into the microphone, which would go away if the case was touched.  I believed this to be a grounding issue, and checked everything I could think to for connection issues, as well as different power outlets, ect.  This problem seemed to clear itself up a few weeks before I first had the problems with the restarting.
I'm including specs, however I've seen this same identical issue mentioned online at several different sites with people who have a wide range of hardware.
CPU = Intel Core 2 Quad Q6600 Kentsfield 2.4GHz
RAM = CORSAIR Dominator 2GB
MoBo= GIGABYTE GA-X38-DQ6 LGA 775 Intel X38 ATX
PSU = OCZ GameXStream OCZ700GXSSLI 700W ATX12V   (Original)
PSU = Ultra LSP 650 Pro 650W ATX (Current)
I'm pretty much down to replacing the motherboard, which isn't a simple option to take when you're a broke college kid.  And I absolutly need the system working for school.  Any advice that could be offered would be appreciated.
  • 565 Answers
Sounds like the cpu is overheating either from bad paste or bad cooling.
Posted on Jan 25, 2009
How to boot dell inspiron one 2020 when it only beeps
the number of beeps will tell you what the problem is the beeps are an error code here are the code list for your computer
Beep Code Description No Beeps No Power, Loose Card, or Short. 1 Short Beep Normal POST, computer is ok. 2 Short Beep POST error, review screen for error code. Continuous Beep No Power, Loose Card, or Short. Repeating Short Beep No Power, Loose Card, or Short. One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard or Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
May 25, 2014 | Dell Inspiron One 2020 All-in-One Desktop
HP Slate 500 won't turn on
It's not the power button. It's something else.It's dropped so there are a lot of problems inside the computer. Get it serviced. If the technician says that you need a new motherboard, then buy a new computer instead because motherboards are expensive.
David
Apr 09, 2013 | HP Slate 500 8.9 Tablet
Athlon 64 X2 5200+, 2.6 GHz desktop only runs on power saver setting
Hello there!
Perhaps it is time to change or recalibrate your battery, some of these particular issues, came from a old or faulty battery. other that that, its a motherboard capacitor blown issue, it can hold electricity, but the capacity to do it came to and end.
Carl
Mar 18, 2017 | AMD Athlon 64 X2 5200+, 2.6 GHz
My system won't boot but there is power
The things to check when your system will not post are RAM (make sure it is in all the way) Hard Drive (make sure it is properly connected) Your CD/DVD drives (again check connection) and your video connection (if you have onboard graphics, this may not apply, if you have a seperate video card make sure it's properly secured in the PCI slot)
Once you've checked all of these things, if you still have a problem, listen for the beeps that come from your computer's motherboard and remember the order of short and long beeps. Respond with the beep sequence and type of computer you are using.
Cheers
Jun 01, 2012 | Gigabyte GA-G41M-ES2L Motherboard
I have an LG 21" monitor. The screen went blank
Without the model number, it is not possible to research this issue. However... My first suspect would be with the software driver. Some system settings do not like to be oscillated too quickly. (I.E.Going in and out of sleep mode for the computer too quickly, or to and from power save for the monitor too rapidly.) This was a problem especially for older versions of windows. (Vista and prior.) Increase power-save to more than 5-10 mins, and check for driver updates. Being that you were able to get it running without unplugging or turning off the monitor, I do not believe it is a monitor issue. (Outside of the RARE possibility of a hardware or firmware conflict between the monitor and video card/chip set.)
Sep 19, 2011 | LG 22" FLATRON LCD Monitor
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
Dell gx620 wont turn on only get blinking amber start button
It is probably in "lower power mode". First try hitting enter a couple times and moving the mouse.
If that doesn't do anything try unplugging the power cord for a couple of seconds and plugging it back in.
If neither of those work the next steps will involve opening the computer (only do this if you're familiar enough).
First unplug the PC before all of these steps...
Open the PC and check to be sure the RAM sticks are securely seated.
Try taking the CMOS battery out for a few seconds then putting it back in. The CMOS battery will be onthe motherbard. It is a small silver coin-shaped battery sometimes used in watches and cameras and other gadgets. Be sure to put it back in the same way it was when you took it out.
If none of that worked check to be sure any other components are firmly seated in their slots.
If none of this has worked I would say call dell support to see what they say.
Jun 09, 2010 | Dell OptiPlex GX620 PC Desktop
One Short beep and two long beep
The beeps you hear are BIOS Beep Codes. Sort of like a Morse code, if you know what that is. Every computer has it's own BIOS program, and version of that program. Each BIOS has it's own Beep Codes.
Taking a guess, as I don't know what BIOS program or version you have, it sounds like a ram memory issue.
Suggest you,
1.Unplug the computer
2.Open the computer case
3.TOUCH the metal frame of the open computer case, to relieve you body of Static electricity. Static will silently fry out your delicate computer hardware components. You won't see it or feel it.
4.Remove the ram stick/s. Reinstall the ram stick/s. (Stick/s means one ram stick, or two, three, or four ram sticks)
You may have just had a loose ram stick.
Apr 28, 2009 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Flatbed scanner
take a volt meter and check the power at the end of the power adapter, sounds like it may be a power issue. if all is ok on that end does it still work on the old system? you may have to hook it back up to a working system and see if there is a firmware upgrade for it. Best of luck
Dec 29, 2007 | Mustek TwainScan 600 III EP Plus Flatbed...
Intel Motherboard Logo
95 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
