Question about HP Office Equipment & Supplies
My fax is hp - HP Office Equipment & Supplies
  • HP Master
  • 7,627 Answers
And your question............is?
Posted on Dec 10, 2012
Can't fax because the fax log is full and want to know how to erase
HI...............
How to Delete a Fax Log History on an HP????
The HP printers come with the HP Solution Center software. The software allows you to adjust settings, transfer images, send a fax and make copies right from the control center instead of using the printer control panel. When you make a fax, receive a fax or block faxes, a log is kept in the HP Solution Center. You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy Instructions
    • 1 Open the HP Solution Center by clicking the "Start" button. Navigate the mouse to "Programs" and click on "HP" to open the drop-down box. Click on "HP Solution Center." If you have the "HP Solution Center" icon on the desktop, you can click the icon to open the software.
    • 2 Click on "Settings." A drop-down box will open up. Click "Fax Settings and Setup," which will open another drop-down box. Click "Fax Log," which will open the fax log window.
    • 3 Read the "Sent Log," which is the first tab on the window. The information will tell you the date, duration of the fax, name of the fax, fax number, how many pages and the status.
    • 4 Click on the first fax in the log to highlight it. Click "Delete" at the bottom of the window to delete the fax. Continue this step for each fax until every fax you want deleted is gone.
    • 5 Click on "Received Log" and delete each fax. Click on "Blocked Faxes" and perform the steps again to delete each of the faxes in this log that you want to delete.
HOPE THIS SOLUTION WILL HELPFUL TO YOUGOOD LUCK.................
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
Cannot get the fax function to work
HP Toolbox and Fax Management - The HP LaserJet all-in-one product software includes a web application to easily communicate with and manage the HP all-in-one product. The HP Toolbox allows monitoring the status of the product, examining and changing product settings, gives access to fax software functionality, allows scanning from the all-in-one product control panel, provides product alert functionality, and presents troubleshooting and "How Do I " content.
Connect an active telephone line to the back of the HP printer. You will see the telephone jack next to the USB port. The HP printer is now ready to fax a document. Hit start and it will work.
  1. Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code. To modify the fax header, use the following steps:
    1. Press the Setup button (c01461502.gif ) on the product control panel.
    2. Press Basic Fax Setup , and then press Fax Header .
    3. Type personal or company information using the keypad, and then press OK .
    4. Type the phone number, including area code, for your HP fax product, and then press OK .
  2. Dial 1-888-HPFaxme, and then send a fax to the HP Fax Test Service.
test your fax working or not:-
  1. Make sure the product is turned on and correctly connected to the telephone jack.
  2. Make sure that there is plain white paper in the input tray.
  3. Press the Setup button (c01461502.gif ) on the product control panel.
  4. Press the right arrow (c01185072.jpg ) to select Tools , and then press OK .
  5. From the Tools menu, press the right arrow (c01185072.jpg ) to select Run Fax Test , and then press OK . The fax diagnostic test print.
Dec 09, 2010 | HP LaserJet 2840 Printer
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
Can I send a fax from my computer via the HP LaserJet M1522nf?
Yes you can send fax from computer.You need one dialup connection with Fax modem. then you need fax software. there are many software availble on the net . One is Mighty Fax. you can download it from the internet and many other you can search in google.
Sep 17, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
Cannot send or receive faxes
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp 640 cant send or receive fax(NO ANSWER FROM REMOTE FAX
Since the fax machine is about 4 weeks old, why not give it back to HP? Warranty still covers it.
May 22, 2009 | Office Equipment & Supplies
Hp4300 series disc won't work with my new hp window vista computer my printer is a 4315v
Please perform the steps given below and check if yuo are able to fax
1. Open a MS Word Document.
2. Click File -> Send to -> Recipient using a fax modem.
3. Follow the instructions given in the fax wizard. Ensure that you select the HP all-in-one as the fax program.
Now check whether you are able to send the fax.
OR
Try setting up the Fax once again
=== Fax Setup wizard ===
- Double-click on the HP Solution Center to open it.
- Go to Settings --> Fax Settings & Setup --> Fax Setup Wizard.
Complete the fax setup wizard and then, try to fax
Vishwanath V U
May 19, 2009 | HP Officejet 4315v All-In-One InkJet...
11 people viewed this question
Seeker5211
Seeker5211
