Washing machine kenmore elite model # 417.42142100 manual
How to remove and clean soap dispenser
  • 1028 Answers
SOURCE: Schematics for washing machine
look under console
Posted on Jul 05, 2008
  • 958 Answers
SOURCE: Removal of washing machine soap dispenser - Indesit
hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 181 Answers
SOURCE: can i put he liquid color safe bleach in machine and which dispenser should it go in
yes in the despenser draw
Posted on May 14, 2009
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
SOURCE: remove and replace fabric softener dispenser on kenmore model 20952992
I just did it. All you do is pull up on the blue part -- put the fingers of both hands under the rim and pull. It isn't screwed or bolted on. If there's a lot of gunk built up, it's all the harder to pull up. Be prepared for some yucky stuff. It would be nice if that whole section would come out, since you have to clean the area below with Q-tips.
Posted on Jan 09, 2010
Why is water coming out of the soap dispenser on a Kenmore Elite washer?
Some washing machines flush the soap/detergent dispenser to remove residue.
Feb 23, 2015 | Kenmore Washing Machines
How do I clean out the soap dispenser of the washing machine?
Hi Mary,
I just did this on my Kenmore front load but you didn't identify your make or model. In my case the soap dispenser is in a drawer that pulls out and by depressing a lever the whole thing could be removed and easily cleaned.
Jan 02, 2015 | Washing Machines
Kenmore front load washer is leaking from dispense drawer, cleaned entire drawer thoroughly and still leaking
Remove the soap drawer and look for a sock or other item that might have gotten stuck in the hose
Nov 05, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite top load that is leaking some water on the floor. I had this repaired before and I know the problem that time was the liquid chlorine bleach dispenser was dirty and needed cleaning....
Usually the soap tray has a black tab at the back of the soap dispenser tray , remove the tray and take a cloth with some CLR and rub the top of the slot were the tray fits into the washing machine. If you look inside you will find that there are holes in there this is were the water come through to wash the soap out, chances are that it is starting to block the holes with either calcium or soap. Hope this helps you out.
Aug 13, 2009 | Washing Machines
Fabric softener dispenser will not dispense ...still full after a load. Soap appears to be working fine. Not sure about bleach.
softener is likely hardened on the solenoid. the dispenser must be removed and cleaned.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Soap Dispenser won't empty
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
He4t dispenser problem soap
Remove the soap tray and clean the orifice.
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore He3t soap dispenser divider missing
You can find a replacement divider at searspartdirect.com. Just type in your model number and look under the "Dispenser" heading on the next page for item number 24 (part number 8181730). There's an excellent exploded view parts diagram to refer to for ease of component identification. I hope this is what you were looking for.
Aug 14, 2008 | Kenmore Elite 45986 Front Load Washer
Soap dispenser
Refer to the manual. You can use a tooth brush to clean out.......
Dec 23, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
179 people viewed this question
Top Washing Machines Experts
