Question about Quantaray QSX 2001 UT Tripod
How do you remove the pan head - Quantaray QSX 2001 UT Tripod
  • 685 Answers
That tripod was not designed to have the head removed. if you do get the head apart, there is no way to attach another head without lots of re-milling and work. Go to www.itripod.com and buy a Manfrotto tripod. these come without head and can easily be up fitted.
Posted on Dec 15, 2012
How do I change my oil pan gasket on my 95 ford Thunderbird, thank you first time car owner
Lift your car and place on jack stands. Then drain engine oil from pan. If there is/are any other steering or suspension components under oil pan, remove these first. Then, begin removing all bolts that hold pan in place. There should be a few bolts that come from the rear of the transmission section that also hold engine oil pan. Remove these. Once all bolts are removed, use a rubber mallet to tap oil pan until is breaks loose. If hard to remove, use a pry bar or flat head screw driver to pry oil pan off. Install in reverse order.
Dec 30, 2016 | Ford Cars & Trucks
Removing steering column shroud on a 2006 sierra 3500, no screws where videos show to remove them there's a recess area but no screws in the locations indicated
Steering Column Trim Cover Replacement
Important: You must check for 2 pan head tapping screws (1,2) in the lower trim cover before removal.
If necessary, remove the 2 pan head tapping screws (1,2) from the lower trim cover (3). Remove the lower trim cover (3).
If screws are not present in the lower trim cover, proceed to the next step.
Gently unsnap the lower trim cover from the upper trim cover.
Important: You must check for 1 TORX® head screw (1) in the upper trim cover (2) before removal.
If necessary, remove 1 TORX® head screw (1) from the upper trim cover (2).
If a screw is not present, remove the upper trim cover (2).
Dec 01, 2016 | 2006 GMC Sierra 3500
How to remove the oil pan
First lift your car so you could get under it. Make sure that you have some device under the car to protect you just in case that the jack fails and the car falls on you. Then remove the screw from the oil pan. Have an oil recipient to ready to collect the oil output.
After that, you may have from 4 to 6 screws to remove. You need to find out the size of the head of the screws and use a ratchet to remove it.
Apr 21, 2014 | 1976 Cadillac Eldorado
How to remove oil pan
Drain the oil first. Then look up a round the edged for a series of about 12 bolt heads that go all the way a round the pan. Remove them and the pan well come down. Old gasket may have it stuck to motor so help it with a good bump. :)
Apr 14, 2014 | 1994 Nissan Pickup
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
Where is the oil drain plug of a 2005 toyota sequoia ?
Look under the engine (not the transmission) for the drain plug on the engine oil pan.
The following is some information on how to change the oil pan:
REMOVAL & INSTALLATION 3.4L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Disconnect the negative battery cable.
  3. Drain the engine oil.
  4. Remove or disconnect the following:
    • Engine undercover
    • Front differential, if equipped with 4WD
    • Oil pan, separate it from the engine using SST 09032-00100 and a brass bar
    To install:
  5. Apply seal packing to the oil pan.
  6. Install the oil pan to the cylinder block. Tighten the nuts and bolts to: 67 inch lbs. (8 Nm) WARNING
    If parts are not assembled within 5 minutes of applying time, the effectiveness of the seal packing is lost and must be removed and reapplied.
  7. Install or connect the following:
    • Front differential, if removed
    • Engine undercover
    • Negative battery cable
  8. Fill with engine oil.
  9. Start the engine and check for leaks.
4.7L Engine
  2. Remove the engine from the vehicle and mount it on a stand.
  3. Remove or disconnect the following:
    • Oil dipstick tube
    • Lower oil pan
    • Oil pan baffle
    • Upper oil pan
    To install: Fig. 1: Upper oil pan bolt location — 4.7L engine 7924sg75.gif
  4. The upper oil pan bolts are different lengths and are identified as follows:
    • A: 0.79 inch (20mm) w/10mm head
    • B: 0.98 inch (25mm) w/12mm head
    • C: 2.36 inch (60mm) w/12mm head
    • D: 1.38 inch (35mm) w/10mm head Fig. 2: Upper oil pan sealant application — 4.7L engine 7924sg74.gif
  5. Apply silicone sealant to the upper oil pan as shown.
  6. Install the upper oil pan and tighten the fasteners in several passes to the following specifications:
    • 10mm: 66 inch lbs. (7.5 Nm)
    • 12mm: 21 ft. lbs. (28 Nm) Fig. 3: Lower oil pan sealant application — 4.7L engine 7924sg76.gif
    • Oil pan baffle. Tighten the fasteners to 66 inch lbs. (7.5 Nm).
    • Lower oil pan. Tighten the fasteners in several passes to 66 inch lbs. (7.5 Nm).
    • Oil dipstick tube
  8. Install the engine.
Sep 01, 2010 | Toyota Sequoia Cars & Trucks
The Pan Tilt Head cannot be removed from my Manfrotto CXPRO3
Extend the center column, there are 3 screws underneath that when unscrewed will allow the head to be tightened or loosened. The head is screwed on about 4 or 5 revolutions. You will need a flat head screwdriver. Take the center column out if you need to to be able to get to the screws.
Aug 24, 2010 | Manfrotto BOGEN 804RC2 Basic Pan Tilt Head...
Replace oil pan on 2000 Jeep Cherokee
DRAIN THE OIL. REPLACE THE OIL DRAIN PLUG. REMOVE THE BOLTS AROUND THE EDGE OF THE OIL PAN. TAKE A FLAT HEAD SCREWDRIVER AND GENTLY PRY THE OIL PAN DOWN. REMOVE OILPAN. MAKE SURE THAT THE MATING SURFACE IS CLEAN AND THAT THE OLD GASKET IS COMPLETELY REMOVED. INSTALL IS REVERSE OF REMOVAL.
May 06, 2010 | 2000 Jeep Cherokee
What is the size of the allen wrench needed to fit the oil pan drain plug in a 1995 toyota celica
The oil pan drain plug should require a 14mm hex head wrench to remove. The transmission pan requires a 10mm allen head socket, or wrench to remove. Are you sure you're trying to remove the correct drain? The oil drain should be on the passenger side and on the rear corner of the pan.
Dec 12, 2009 | 1995 Toyota Celica
How to remove pan head from velbon 530, it feels very tight
I have the Hakuba HG-503MX which came with basically the same pan head you have already attached to the center column. First remove the center column from the tripod, with the pan head attached. Tighten the knob that prevents the pan head unit from rotating 360 degrees on the center column and gripping the head with one a hand and the center column near the plastic plate firmly twisting the head counter clockwise. The pan head will unscrew from the plastic plate which sits on top of the center column, given enough force. My pan head was also very tightly screwed onto the shaft, since it came already attached to the tripod. Hope this is helpful.
Aug 10, 2009 | Velbon EL Carmagne 530 Tripod
Quantaray QSX 2001 UT Tripod Logo
300 people viewed this question
Top Quantaray Photography Experts
JP Services
JP Services
R.A. Ellis
R.A. Ellis
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
