Question about Empire Heating & Cooling
Humming noise from furnace.
I have an empire wall furnace model faw-55-spp. When it is plugged in the wall outlet there is a rather loud and consistant humming noise. This happens even when the unit is not running. Any thoughts?
SOURCE: loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Posted on Mar 21, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Posted on May 30, 2008
  • 80 Answers
SOURCE: i have a empire propane wall furnace
Check with the manufacturer. Many times these companies offer accessory kits for such application. You will need unit Model #.
Posted on Oct 03, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Our new Empire wall heaters are loud. Do they
Rinnai are the quietest I know of. Rinnai.us
Posted on Mar 01, 2010
  • 4736 Answers
SOURCE: Empire FAW-60-2-spp fan short cycles
From what you have described, it sounds as if the Fan Control Switch, ECS Part # R-1941, which works in conjunction with the Limit Control Switch (ECS Part # 912073) is failing and needs to be replaced. You can order these parts directly from Empire Comfort Systems. If you decide to replace these parts yourself, it will give you an opportunity to thoroughly clean the interior of the Wall Furnace, if you haven't already. If you need further information, contact Empire Comfort Systems, Technical Service @ 800-851-3153 Monday - Friday.
Hope this helped you to troubleshoot the problem. Please don't forget to rate my response. Thanks!
Posted on Mar 27, 2011
Faw 55 no fan operation
All fan switches should read open line or "OL" when the furnace is cool, but if the motor seems stiff see if it is oilable. It may have small holes covered by yellow or black plastic plugs covering the holes. If it does and you have not oiled it, go to the hardware store and ask for a motor oiler such as a Zoom spout. Place 3-5 drops of oil in each hole then spin the motor by hand, it may loosen up. The limit side of the fan/limit switch has no impact on the fan motor.
Feb 01, 2015 | Empire Comfort Systems EMP FAW-55-SPP-1N -...
EMPIRE MANUAL DV2353SG
I believe all the Empire manuals are there to download or read at their website: EmpireComfort.com.
Nov 08, 2011 | Empire Direct Vent Wall Furnace;...
Empire FAW-60-2-spp fan short cycles about 4 seconds on/off
Mar 27, 2011 | Empire Heating & Cooling
We have an old furnace. Model # em50743b Serial #55673 45k - 65k BTU Piloit stays lite. Very low flame when furnace kicks on...then humming noise begans and gets louder. Now will not come back on.
That sounds like your gas valve went bad...
If it is very old you may have a very hard time finding a replacement for it...
depending on the configuration of the gas train you may be able to update to a newr valve but then maybe not...
You may have to get a new furnace...
heatman101
Nov 17, 2010 | Montgomery Ward (223600UP) Heater
Have an empire wall furnace. Natural gas. Vent through the wall. My problem is that sometimes when it ignites, it makes a loud boom and I can see a flame flash at the top of the heat exchanger. I was...
Not sure what the problem is, but mine does the same thing.It also blows the pilot light out when it does it..Had several service calls, no luck...POS, don't buy another Empire heater....
Nov 09, 2010 | Empire Hight Efficient Direct Vent Wall...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
I have a empire propane wall furnace
Oct 03, 2009 | Heating & Cooling
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Pilot lights and one panel burns
Empire faw 40 makes a loud bang when starting up. There are three burners. The pilot light is on one burner. When the furnace starts, gas is lit on that burner and the flame is passed on to the other burners by a small channel that can get stopped up. You just have to remove the burners and clean the channel with a small file, like on a finger nail clipper. This can be difficult due to the pilot assemble being attached with two bolts. The bolt on the right has to be removed with a short screw driver. You can not get a socket on it. After you remove it there is enough play to remove the bracket and gas burners.3_4_2012_5_06_50_am.jpg
Nov 23, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
65 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
