Question about Music
M-audio keystation pro 88 mod wheel calibration
Mod wheel center position defaults to 56 instead of 63
I have an M-Audio Keystation 61es. Lately I've had random loss of power through the USB2.0 cable. The cable still powers my other M-Audio products, so the issue is the Keystation. It is possible...
I have the 88 key ones and powering via the USB is marginal... IF you have a place for an adapter, use one, as the computer USB is limited to 1/2 amp and OFTEN they limit at a little less and then the keystation is not reliable...
Aug 30, 2011 | M-Audio Keystation 61es USB MIDI...
Does this keyboard only work with a computer or can it be used separate to it?
It has a limited voice generation capability. There are L and R audio outputs on the back... Just don't expect every fancy synth voice to be in it...
Aug 25, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
How to turn on en off the moulation of a korg x5d
For Combi/Multi patches you can disable control changes for each sound under EDIT 6D but this also switches off other control change instructions (pan, expression, pedal etc.).
Somewhere under GLOBAL settings you should be able to find the modulation wheel Depth setting and set it to 0 which should stop your mod wheel from working but you could achieve the same effect by just keeping the mod wheel pulled all the way down.
Jul 28, 2011 | Korg X5d
I recently purchased the Keystation 88es and I have installed the Able Live Lite 6 on my computer. I have installed the USB MIDI series 5.0.1 from the M-Audio website. I have plugged in the usb port as...
First step is to download Midi Monitor http://www.snoize.com/MIDIMonitor/
just to make sure you're actually getting midi over USB into the computer. This is a great utility that I use all the time for troubleshooting midi data issues.
Feb 28, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
I just bought an M-Audio Keystation 88ES. I have a used Behringer expression pedal. The pedal works fine in the sustain input, but when I insert the jack in the volume input it cuts all power to the...
If the power goes off when you plug in the pedal, the pedal LIKELY has a short in it between two of the three connections at the plug.
Firat, try putting the pedal plug in BEFORE applying power.
Likely the pedal presents a pot or volume control that will have like 5 volts across it an the wiper returned on the same cable. If the wiring configuration is wrong OR if the plug goes through a period of shorting the 5 volts out during insertion that will cause a problem...
To troubleshoot, move the pedal to half way and these with an ohmmeter for shorts between ANY two of the three connections.
Jan 28, 2011 | M-Audio M Audio Keystation 88es 88 Key USB...
My child jammed something inside of my keystation pro usb connector.... Broke the copper connectors inside.... Whats the best way t go about this ... replace the entire piece or soder in a new copper line
If the traces are lifted, then use jumpers to the points of origin of each trace. Tack the jumpers down with silicone seal or other adhesive.
Replace the connector ifthere is any chance of damage to the connector itself.
Oct 14, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
Keystation 61 key won't play
Most of these use conductive rubber pills that are pressed onto circuit board traces by the keys.
Clean the board AND the pills with 99% isoprophyl alcohol and QTips.
May 31, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
M-audio ProKeys 88sx -- all led lights flash, no sound Upon turning the keyboard on, all led lights on the top panel flash. No sound from the keyboard. Is there a re-set button or something?
I have two of these. First thing check your power adapter for output. Just because LED's are on doesn't mean there is correct voltage... There is no reset button... Cycling power serves to reset it.
ALSO check the power input connector... sometimes those get intermittent and break connection due to vibration and initial current surge when turning on.
M-audio 88es, I plug into my laptop using windows xp and no sound
You have to install software to connect the device to the General MIDI input. This rquires a driver for the 88ES.
Mar 08, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
The prongs on the USB connector broke off. Do we need to replace a board and if so how do we do so?
You can buy new connector and replace broken one. You need skill at soldering and of course have to open the unit to access the broken connector.
Oct 10, 2009 | M-Audio M Audio Keystation 88es 88 Key USB...
Music Logo
53 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
