Question about Texas Instruments TI-5630 Calculator
TI-5630 won't total, or any other function button, + - x etc.
Only the numbers buttons seem to respond. Just gives me one continuous line of numbers, with no addition, subtraction, etc. of any other function.
  • stephenmacie Mar 18, 2009
    one continous line of numbers -- add, subtract, and all other function buttons won't work.
  • Anonymous May 07, 2009
    Same problem!
3 Suggested Answers
SOURCE: fractions
When performing the calculations, put the fractions in parentheses. Then once you get your answer, press 2nd and Math (above the times button). Then press F5, MORE, and F1. It will have Ans Frac>. Then hit Enter and it'll change it to a fraction.
Posted on Feb 05, 2008
  • 7993 Answers
SOURCE: Hello! My TI-84's multiplication, division,
Did it start doing it on its own? Or did this condition appear after you played some third-party game? If the last case is the correct one then the game may have reconfigured the keypad.
  1. Try to exit the game from inside the game.
  2. Remove the game from the Ram.
  3. Press [2nd][MEM][2: Mem Mgmt/Del][1:All]
  4. Use the down arrow to scroll along the list of objects in memory.
  5. Find the offending program.
  6. Use down arrow to point to the program and press [DEL].
If the program has an asterisk to the right of its name, it is archived. If you press DEL you will be asked if you want to delere it. Enter the number to the right of Yes and press [ENTER].
You may have to wait for the calculator to defragment the RAM.
Posted on Feb 07, 2010
Remote won,t work all functions for yamaha 70cu sound bar
Set-up the remote control with an other set-up code said for your device.
Sep 24, 2015 | Yamaha Televison & Video
How do i use the x,t,e,n button
The function of that button depends on the current graph mode. It will give you the "n" only in the SEQ mode. Press MODE, cursor down to the "FUNC PAR POL SEQ" line, highlight "SEQ", press ENTER 2ND QUIT. Now pressing that button will give you the "n".
Apr 10, 2014 | Texas Instruments TI-84 Plus Calculator
E^ won't work
You are not using it correctly. To calculate the exponential of a number you use the key sequence [SHIFT][LN] to access the exponential function. Then type it the exponent (positive or negative) and close the parenthesis.
You do not use the power key (^)
The exponential function is not affected by the angle unit when you are using real values.
Jul 03, 2012 | Texas Instruments TI-84 Plus Calculator
My son has a TI-84 Plus calculator and it is completely frozen. There is a message on the screen that reads " RAM cleared". Below that message it says "Press ALPHA F1-F4 to locate shortcut menus" but it...
The calculator OS has been upgraded to the version 2.53 MP.
For this version, whenever you remove batteries (or replace them) and turn calculator ON, you are reminded to Press [ALPHA][F1-F4] to locate Shortcuts Menu.
The calculator also asks the user to press either
[1:Do NOT show Again]
[2:Continue].
Here is what these cryptic messages mean.
Certain functions implemented on the new OS are available by pressing the [ALPHA] key followed by F1, F2, F3 or F4.
Since you may forget how to get to them, the calculator gently reminds you that there are other functions accessed only by pressing the [ALPHA] key.
It also gives you the option to flash the reminder every time the calculator memory is reset (CONTINUE) or NOT to SHOW the REMINDER again.
Usually after the RAM cleared message, press [2:Continue] or any other key but [1: ] to keep being reminded how to access the new functions.
Once a key is pressed the screen is cleared and you have the solid blinking cursor.
Oct 06, 2010 | Texas Instruments TI-84 Plus Calculator
My TI-84 Plus Silver Edition's Y= has an unusual setting. What I mean is that the side figure gives me a Play, Fast Forward like settings, when I want it to be lines. Also, I can't input two functions at...
You must have used the TRANSFRM application before. It remains in memory and takes over the graphing function from the native OS. You must unload it from memory.
  1. Turn calculator ON
  2. Press the [APPS] button.
  3. Scroll Up (faster) or Scroll down till you see :Transfrm in the list of applications.
  4. Highlight that line and press ENTER.
  5. The new screen invites you to Uninstall or Continue
  6. Press the number key that corresponds to the Uninstall option (1:Uninstall)
  7. Return to your [Y=] editor screen to verify that the style lines have changed to the "normal" ones.
Sep 01, 2010 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus calculator without ~ | or y keys
type 15 then click a button that looks like this^. then 365. Then hit enter. it is like a normal clcutor except with more function. Sometimes you need to use the 2nd and the alpha button to do some functions.
Jan 17, 2009 | Texas Instruments TI-84 Plus Calculator
Screen frozen calculator not responding to buttons pressed.
give it a factory reset, this works, you will lose any unarchived data : http://www.associatedcontent.com/video/265/how_to_reset_a_texas_instruments_ti89.html?cat=59
Aug 30, 2008 | Texas Instruments TI-89 Calculator
Acer Aspire 5630 screen brightness adjustment...
You press the function (Fn) key and the left/right arrows, not the Ctrl / Alt, shift buttons
Oct 26, 2007 | Acer Aspire 5630 Notebook
Texas Instruments TI-5630 Calculator Logo
66 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
