We purchased a GE Washing Machine (Model WDSR2080G) in 2007. I had to replaced the Control Knob and now a washing cycle takes approx 2 hours ! Do I have to resent the knob somehow ?
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
duby1990
  • 367 Answers
SOURCE: how does the timer knob come off
Push the knob to the off position then spin it to the left. it should just screw off. There is only one or two models that dont. To acces the timer you have to take the 2 screws out of the corners of the control panel (philips) They are either on the front or the back of the machine, left and right corners. The whole control panel will pull forward and then lift up and flip back. Theres the timer. Any more questions let me know.
Posted on Nov 21, 2008
SOURCE: GE washing machine water overflowing
sound like the same washing machine from hell that we have. three or four times it has overflowed from want we have been told the hose that runs from the drum to on/off pressure switch cloggeds with soap. we have tried different soap,hot water,cold,water you name it we've tried it. so now evey time we use it we have to clean it with a coat hanger by taking the front off the machine.
P.S. take the hose off top and bottom to clean it, all it takes two/three very small soap bubbles to clogged it
Posted on Dec 30, 2008
SOURCE: Washing machine will not drain.
I have the same problem. If I press on the lid by the switch it starts up and finishes the load. Hope this works for you!
Posted on Dec 11, 2009
The hour cycle now takes only approx. 20 minutes
faulty timer or control board chip
is your machine listed on this site
http://www.venturamalta.com/washing/
May 11, 2016 | Blomberg Washing Machines
I have purchased a house with the single door dishwasher and it takes forever to wash - about two hours - what could be the problem?
Check your program settings. If wash quality is good, it's OK. Check your inlet water has sufficient pressure! Refer user manual
Apr 07, 2010 | Fisher and Paykel DS603SS Stainless Steel...
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Jun 18, 2009 | Kenmore Washing Machines
Program knob on GE washing machine not functioning
Older washing machines had a 2 position knob push or pull to set and the other position to run, also if the timer is bad it can be replaced the parts are still available on the Internet.
Have a good day...
Tim
Mar 26, 2009 | General Electric Washing Machine Chrome...
Samsung WD-J1255R washing machine takes double the displayed time
The problem is surely with the clock timer or the control board (cannot be repaired).I hope the product is under warranty, you can better have it replaced.Good luck.And please do post your comments.
Jan 16, 2009 | Samsung Washing Machines
Oct 28, 2007 | Washing Machines
Sep 13, 2007 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
