Question about Garmin GPSMAP 498 Fishfinder / Chartplotter GPS Receiver
Garmin GPS 498 Map Backlight dim
Thank you . Product is Garmin GPS Map 498 [internal antenna] Are there any fixes for the dim backlight even when brightness is on high? Please send me reply e-mail : nomur@tstt.net.tt Greetings from Trinidad & Tobago ++++++++++++++++++++++++++++++++++++++++++++
  • 10 Answers
SOURCE: Cannot load map in my Garmin Streetpilot i3 GPS
i dont think you can upload maps to an i3, it can only load pre-loaded maps on micro-sd cards.
Posted on Oct 04, 2007
  • 174 Answers
SOURCE: changed battery garmin ique no backlight
Most likely you broke one or both wire that supply power to the LCD. There are two ribbon cables to the LCD and two (black, white) wire. The ribbon cable cables supply data signal to the lcd and the smaller cable is the digitizer signal. The power wire (black, white) wires are soldered to the circuit board. And since these are LED lights there is a plus and minus and they have to be soldered correctly.
But before taking apart the IQUE 3600 did you try adjusting the brightness level?
Posted on Dec 31, 2007
marcelbakker
  • 174 Answers
SOURCE: deleted maps on my garmin gps nuvi 255w now what???
Wasn't there a dvd with the product?
Posted on Jul 23, 2008
sharcnet
  • 2130 Answers
SOURCE: "No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Posted on Dec 13, 2008
  • 59 Answers
SOURCE: garmin gps 95xl battery
The battery is a Panasonic VL1220. See my local post here about replacement.
Posted on Apr 25, 2009
How do I fix the backlight of my garmin 3205
The LCD display contains both the display and backlight. They are integrated as one piece. Therefore the entire display needs to be replaced. The backlight connections are soldered to the LCD connections. Replace the entire display.
Dec 25, 2014 | Garmin nuvi GPS
HOW TO REPLACE INTERNAL BATTERY FOR GARMIN 498
It has to be sent back to the factory to have it replaced. Contact Garmin support for your country and they will give you instructions.
Jul 19, 2014 | Garmin GPS
Garmin gpsmap 498 backlight
Did I understand this right, you do know how to replace the backlight, but you cannot locate it inside the unit ? Try to look here: http://goo.gl/6hCS
Jan 02, 2013 | Computers & Internet
How do i find my product key for my nuvi250
The Garmin product key, also called the product serial number, is included in the box your Nuvi i250 comes in. This number is nine digits; it's printed on the yellow specification sheet. Fortunately, the key is also printed on your Garmin unit, which is helpful in the event you lose your specification sheet. The Garmin product key is required to register your Nuvi i250 with Garmin. (Registration allows you to download software and map updates, and receive recall information.)
Follow the procedures below on your nuvi i250;
  1. Turn your Nuvi i250 around to view its back.
  2. Flip up the GPS antenna with your finger. Look behind the GPS antenna for the specification sticker.
  3. Write down the nine-digit product key. With this number, you'll be able to register your Garmin. (See "Resources.")
Good luck
May 17, 2010 | GPS
The backlight on garmin legend is dim - how do i brighten it
When the unit is on, press the bottom right side button on the GPS unit. A slider will appear to increase brightness, use your toggle to move the slider up.
Hope this solves your problem. If so, please come back and tell us, and rate our solution. Thank you.
Dec 20, 2009 | Garmin eTrex Legend GPS Receiver
How can I download a manual for a Garmin Gps 498
Here's the link to download the manual for free. If this solves your problem, please come back and rate our solution.
https://buy.garmin.com/shop/shop.do?pID=370
Jul 31, 2009 | Garmin Gpsmap 498, External Antenna With...
No backlight on my Garmin IQue 3600
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Feb 03, 2009 | Garmin iQue 3600 GPS Receiver
Garmin Nuvi GPS won't acquire satellites
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Dec 04, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 498 - trouble finding satellites
Push power/menu together or power/page together. the whoole unit will reset. you will lose all saved data but this may help
Nov 07, 2008 | Garmin GPSMAP 498
Mapupdate
Hello SaSSAFRASS,
Map updates for all Garmin GPS products are available via the Garmin website. Just go to https://my.garmin.com/maps/updates.htm
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin GPSMAP 498 Fishfinder / Chartplotter GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
