Question about Exercise & Fitness
I have a sportcraft tx 5.0 rc treadmill. My treadmill runs for seven seconds then turns off with a three on the left side of the screen. I read up on this and saw that its an error code 3 meaning issue with the speed sensor. I've tried adjusting the position of the sensor with no luck. When I turn the black disc wheel the red LED blinks dim to bright, so it looks like the sensor is registering. Though when I turn it on and run it, the LED go solid red( I was thinking of because how fast it's spinning). But I'm not sure what to do at this point.
    Top Expert:
  • 12,223 Answers
See the video how to lube and proceed according. use silicone or wax.
lube the rollers bearing too.
test the input voltage motor, if there are the motor need repair, see my personal TIPS for motor help
test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram attached
God bless you
Posted on Dec 10, 2012
3 Suggested Answers
SOURCE: Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Posted on Jan 08, 2011
  • 33 Answers
SOURCE: My TX 5.0 RC Sportcraft
You will have to unscrew that part out of the treadmill and take it out, and then put it back in to see if that makes any difference. If for some reason that does not work, you may have to contact the company to get a replacement on your treadmill, or to see if they wil fix it for you. Since each treadill is different, defects are inevitable, so a person will have to use consider going this route if all else fails.
Posted on Jul 13, 2011
Treadmill speed varies with or w/o load. Belt not loose. Led speed indicator constant.
0ed98914-d0ff-4c07-aa5a-486eca10f03f.gif1) adjust the speed sensor see the diagram, clean the sensor very well, tight the connector very well.
2) LUBE the deck belt with silicone or wax READ your owner manual,
God bless you
Jun 03, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Tx 5.o rc sportcraft treadmill varies in speed with or w/o load.
1) adjust the speed sensor, see the diagram attached, test for open or faulty. clean it very well. tight the connector very well
2) LUBE the treadmills very important . do it with silicone or wax. Read your onwer manual for verification.
Tx 5.0 rc treadmill by sportscraft, manual
Did u find out the problem? Mine just started doing the same thing.
Apr 13, 2013 | Sportcraft Exercise & Fitness
TX 5.0 RC just stopped a # 3 came on the screen. After reading several posts we looked at a wheel within the motor compartment(not the wheel with the belt, it's the wheel to the left if your looking...
Info from PDF files located on Sportcrafts website under manuals.
E3 - No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don't tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Also:
Use an epoxy to glue it. It is a plastic that is difficult to adhere to.
Jan 22, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Sport trac treadmill shuts off after a few seconds
1) LUBE the deck belt, this produce enough friction, by lack of LUBE
2) Lube the roller bearing, very well
3) Test the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
See the block diagram. God bless you
May 27, 2012 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
How do I turn on my tx 5.0 rc sportcraft treadmill if I can't find the key
DEAR SIR:
Go to any Hardware and to buy any small magnet, since the key is smal magnet, Do it by small pennies.
Apr 22, 2012 | Exercise & Fitness
My TX 5.0 RC Sportcraft Treadmill stops and show in the screen a #3... Start normal, but in seconds stops... I want to know how to fix it... Thanks...
Jul 13, 2011 | Exercise & Fitness
Sportcraft TX 2.5 treadmill - error code 3 - stops after a few seconds of operation. ??? Thanks for any advice
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Jun 28, 2009 | Exercise & Fitness
Exercise & Fitness Logo
193 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
