My curtis mp2029uk mp3 player has been charging now for 6 hrs how long should it take to charge.
My mp3 player has been plugged into my computer charging for 6 hrs now how long should it take?
  • 3 Answers
SOURCE: I have a Curtis Mp3 player, model MP1012UK. have
if you have windows xp  vista or windows7 plug it into your pc via usb and windows will instal it if it is turned on then look under my computer for a new hard drive this will be it
Posted on Dec 27, 2009
SOURCE: I just bought a Jensen smpv-2gbub player. How do
How to charge the Jensen MP3 player - Model smpg-v2bub
Ignore instructions that came with it - they don't work.
Here's how to charge - I discovered this with mine:
1. When computer is on and at windows screen, attach cable from computer to mp3player with mp3 turned player off. It will immediately show you a connect screen on the mp3 player.
2. pressed the left side middle button twice - this will turn it on and go into music like you're playing a song.
3. Now turn the mp3 player on by switching the button on the right side of the device to the on position. It will suddenly show you it's charging - the battery on the front of the mp3 player will have a signal pulsing through it.
4. It will turn off after one minute. It's literally half charged now. Strange I know. Repeat from step 1 and it will fully charged.
If it doesn't fully charge after it turns itself off after 1 minute the 2nd time, then repeat steps from 1, one more time, but this time when it turns itself off after a minute, still leave it connected to the computer for 10 mins even though it looks like it's off. Then disconnect it physically from computer, turn it on with the on button on the right side, press the left side middle button twice and look at the battery on the screen - it should be fully charged now.
Posted on Apr 22, 2010
Testimonial: "Thank you very much, that would have been very helpful. Truth is, it was my fault, I was pushing the ON button instead of sliding it. DUH Peggy!!!"
SOURCE: Coby MP-C7095 Won't turn on
On my Colby player there is a small reset hole in the back. Mine has sometimes just stopped playing and shuts off. If you use a small wire (paperclip works well) push it in and reset it.
Posted on May 20, 2010
  • 14 Answers
SOURCE: same problem i just read: have a jensen mp3 player...
The player has to be on to charge It will not charge when it is off
Posted on Nov 18, 2010
SOURCE: just bought sylvania smpk4600 mp3 player and
Did you hold down the play/pause button? Instructions say to hold that button (last one on the right) down until it turns on.
Posted on Mar 04, 2011
I charged my 2GB SENSEI mp3 player for more than 4 hrs...but still its not working even for 10 to 15 mins......so wat is d time required for full charging....
Depending on the age of the mp3 player, the battery may be shot and you may need a new one. mp3 players tend to get heavy usage and the batteries can die and get burnt out quickly especially if they are not charged properly. Try draining the battery until it can no longer turn on. Then charge your battery for 6 hours. Good luck.
Mar 01, 2011 | Computers & Internet
I have an Curtis MPK4099UK MP3 Player. It says to charge it I need to install setup.exe from the CD. After I done that I restarted my computer then I put My MP3 Player on charge,(with the on switch) It...
I had the same problem but have now resolved as follows. Turn the top switch to on and connect via USB port. Picture should come on the mp3 player indicating it is connected. For some reason unknown to me in order to charge you need to turn the MP3 player on - but this is impossible if there is no charge. What you need to do now is leave the MP3 player connected like this overnight - it will then have gained enough charge in the morning so that when you then disconnect the MP3 player from the USB lead you are able to actually turn it on. PLEASE NOTE this is not turning on by the switch at the top. What you do it press and hold the circle/dash symbol i.e. at the bottom of the white keypad bit on the front of the MP3 player. As you then let go it comes on. Let it finish turning itself on, then reconnect to the USB lead and leave over night to get a full charge. Good Luck
Sep 25, 2010 | Curtis MPK2066 MP3 Player
Apr 07, 2010 | Jensen Audio Players & Recorders
Need charging instructions
Charging device: Plug the device into computer. You can unplug the device any time you want without problem with device
If your device's battery has empty, you need 3 hrs to charge to full.
If you want to check battery level during devive plug into pc: (set up MTP or Auto mode) open My Computer, right click on icon of the device, select Properties, it shows you batteries level
Feb 02, 2010 | SanDisk Sansa Clip MP3 Player
I cant get my coby mp3 to charge?
That's because u didn't plugged in your computer. Your computer have to be turned on..
Dec 26, 2008 | Coby MP-C7085 MP3 Player
Phillips 6045/37 - Charging
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If it fails to charge after 3-4 hrs, or fails to keep charge once unplugged, get the mp3 player replaced.
Aug 17, 2008 | Philips GOGEAR SA6045 MP3 Player
Problem with sansa e260
that happens to me too. i think the problem is that your computer can't like, sense that it's plugged in, so your battery's dying out, and the computer wont charge it
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
Player is not turning on
Sometimes I must hold the play button down for over 7 seconds on my unit to get it to turn on. See also the answer to the question on properly charging the unit; i.e, have the slide switch in the "off" position.
If you are using a USB hub to charge the mp3 player then the hub must be powered.
Jan 02, 2008 | Coby MP-C582 MP3 Player
Charging
If it just has a usb cable for charging then yes you would. The charging time varies but it generally shouldn't take longer than 3 hours to fully charge. Check your manual if you have one, it will give you more information.
Oct 24, 2007 | Audio Players & Recorders
238 people viewed this question
 Grubhead
Grubhead
