Question about Sewing Machines
Pedal isn't working
Seems like no power outcome from pedal
  • Sewing Machines Master
  • 1,564 Answers
They do break. Search for a replacement for your MAKE AND MODEL.
Posted on Dec 13, 2012
I need help getting this babylock serger Model EA 605 to work
try making sure the power cord is securely plugged into the machine
also the make sure the foot pedal is also securely plugged into the
machine make sure the outlet also is working
Nov 14, 2012 | Sewing Machines
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
What's your problem?Have a TOYOTA EZT9000 and it seems to have slowed quite a bit. Does it need oil? If so, where do I put it in?
there are other things that can cause the machine to slow down
like the motor, foot pedal, have you checked these things first
1. is the power cord plugged into the outlet securely
2. is the power cord plugged into the machine correctly
3. is the foot pedal plugged into the machine correctly
4. is the cord to the foot pedal caught in the foot pedal
if none of these are the problem, then the machine needs to be serviced
to see why it's running slow
May 01, 2012 | Toyota EZT9000
It was working fine. Then stopped. When you depress the pedal the motor idles but the needle doesn't go up and down
it's possible that the foot pedal has gone out
check to make sure the power cord in inserted into the machine correctly & also the foot pedal
Apr 02, 2012 | Sewing Machines
Serger randomly stopped working, could it be power cord? plug?
Make sure there isn't lint caught on the loopers if it is not a loose connection from the machine/wall. On some machines, if the bulb has blown out, the machine will not operate until replaced. It sounds to me like fabric or thread is caught and, therefore, your machine has temporarily stopped until you unplug it and remove the debris.
Hope this helps!
Jimmy
Apr 01, 2012 | Singer QuantumLock 14T948DS Mechanical...
Why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Mar 27, 2012 | Sewing Machines
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
My singer will not stop running untill i pull the elec plug
it possible that either the foot pedal isn't working correctly
or the switch to the sewing machine is not work correctly
it needs to be serviced
Jan 17, 2012 | Singer Sewing Machines
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
I have a Kenmore sewing machine Model 158, 1792280. The foot pedal is not working well; I was sewing normally and when I finished, I removed my foot from the foot pedal but the machine continue sewing. I...
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
Jun 12, 2011 | Sewing Machines
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
