Question about Delta 31 - 255X X5 18'' x 36'' Drum Sander
Delta 31-250 saander dc drive motor doesn't work
Have a voltage reading at plug to motor. No motor response or heating. Anything else to check or do?
    New Friend:
You have probably tripped the breaker for the drive motor. If you have the manual, it shows you the location of the reset button on pg. 20. The reset is a small white button above the drive switch. You can download the manual from this link: http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&ved=0CG8QFjAJ&url=http%3A%2F%2Fwww.redmond-machinery.com%2FManuals%2FDelta%2FDelta%252031-250%2520-%2520OM.pdf&ei=VfcfUba3FYeXyAHGrYFI&usg=AFQjCNGcOLvprmIo_af4ofEd10DBnJ7ocQ&bvm=bv.42553238,d.aWc
Posted on Feb 16, 2013
2 Suggested Answers
protek480
  • 1723 Answers
SOURCE: my delta 31-250 sander dc drive motor will not
Did the DC drive give you a fault code? It may have tripped on a current over load. Needs to be set to handle load.
Posted on Jun 30, 2009
I have a 4500 John Deer tractor that typically won't start in cold temperatures (i.e. 39 or below) otherwise it starts promptly. I've pushed the key in to heat the glow plug a minute or more.
The 4500 John Deere tractor sounds like the glow plugs are not working. Checked voltage at the glow plugs to make sure that there is 12 DC volts.(Might have to remove main wire from the glow plugs to check!) If no voltage at glow plugs there maybe a bad fuse,relay or wire connection in the glow plug circuit. If there is 12 DC volts at the glow plugs, it is possible that the glow plugs need to be replaced.
Jan 01, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Heating problem
Sep 27, 2012 | Microwave Ovens
Fan on paslode does not work after cleaning
It is activated by the micro switch near the top of the tool. It is pushed on by a metal arm with a roller at the end of it. Now I am going to assume the fan is plugged in at the motor and the ground wire is installed. If so you can partially disassemble the tool and CAREFULLY, keep fingers away from the fan, manually activate the little switch to see if the fan works. If it doesn't then either the fan motor went bad or it is a bad micro switch which is part of the circuit board. To see if it's a motor or board you can test for DC voltage with a basic multimeter at the wiring plug where it goes into the fan. If there is voltage (compared to what the battery has for a charge) to the motor then and it doesn't work then that is most likely bad.
If the fan works when depressing the micro switch then check the items to activate it. A model number always helps as then I can bring up a parts diagram which makes it easier to explain.
Jul 01, 2012 | Air Tools & Compressors
Delta 1313314 motor runs but blade doesn't turn
With this perticular motor I would suspect that the issue is a broken drive belt. The belt is located on the back side of the motor, behind the plastic end cap. The belt is a 10" long cogged belt and looks like a timing belt.
Jan 20, 2012 | Delta Saws
When I click the power button on my harddrive the power doesn turn on. I removed all of the plugs and nothing happened
If your not getting any power use a multimeter on the hard drive power cord,, probe orientation doesn't really matter you just get a negative reading if it's reversed. One probe down the middle one of the metal on outside of power adapter. Can't get a probe down middle just stick a paper clip and just probe to that. If it is getting voltage then the dc jack inside the hard drive enclosure could have broken loose take something pointy and gently push the jack on the hard drive if it wiggles it's broken and needs to be re soldered. Comment back for more assistance if needed, General solutions below
Check the following
  • With the drive plugged in on powered on place your hand on it should be able to feel it vibrating (if no its not getting power or dead)
  • If power and vibrating put your ear to the drive (repeating and squealing are bad, crunching sound is generally ok)
  • With the drive plugged in and it sounds ok and it's vibrating[platters are spinning] right click on "Computer"/"My Computer" select manage > Disk Management, locate your drive if it is listed try to initialize it
  1. Right Click drive, properties, hardware tab, select drive, properties, volume tab and click populate
If it wont populate or doesn't show at all in storage manager at all either the drive itself is bad or the control in the external enclosure is bad. You can attempt to remove the drive from the enclosure and plug it in directly into the computer but this tends to void it's warranty. If the drive works however you can simply buy a new enclosure for about $12
Comment back if you need more assistance
Aug 30, 2011 | Western Digital 500GB My Book Pro-External...
How do I replace the radiator cooling fan motor on a 1995 Ford Taurus? How would I check it to see if it is bad?
You disconnect the plug at the fan
Then apply battery voltage to one side &
ground to the other
It is a dc motor so it will run either direction
You just need to see if it works
Doesn't matter how you wire it up
If the fan is good then you may need help
If you see a screw in fan switch in the bottom
of radiator you can test it with a meter with
the wire connector off
You shouldn't have any reading with coolant cold
& if it works when motor is warmed up it will give
you a meter reading
You can use OHMs or your buzzer feature
Jun 09, 2011 | Ford Taurus Cars & Trucks
Delta Side Kick table saw will not start,
If there is no response at all, check the circuit breaker on the motor. There is a heat triggered breaker there. That is the most common cause of this. If that is not the case, please update this and we'll look further.
Dan
Feb 01, 2010 | Delta Saws
Delta 31 - 255X X5 18'' x 36'' Drum Sander Logo
144 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
