Question about Tefal 67610 Kaleo StoreAway 6 Cups Food Processor
Looking for a replacement part for kale strawy 6762.42 food processor
My processor is a 6762 not 6761 and I need the citrus press support.
When the top section is clicked on and on button or pulse or dough button pressed it doesn't go. took top off and pressed the little black button to simulate top being put on and still no result.
Try taking the bowl off and pressing the safety switch with a screw driver. If the processor turns on then you have a problem with the bowl, if it doesn't turn on then the issue is inside of the food processor, and usually internal parts are not available.
If you can find your model & brand information off of the base of the food processor we can look up replacement parts for you.
Thank you,
colleen @ mendingshed.
May 12, 2015 | Food Processors
In need of Bowl and blade
GENERAL ELECTRIC FOOD PROCESSOR MODEL 106622F WORK BOWL
I was able to locate a bowl for the 106622F processor on E -Bay. You may be able to find a blade on E-Bay. From what I gather, there is no source for replacement parts, other than used parts. I hope this helps ! Good Luck....
Mar 31, 2014 | GE 106622F Food Processor
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
My model number is FP1450 and it is a Black and Decker Quick and Easy. I am looking for the bowl(?) that attaches to the base that will contain the processed food. Is this part stil available for...
my model # is FP1450 and it's a black and decker quick N easy food processor. I'm looking for a replacement slicing/shredding blade. where can I get this?
Aug 13, 2010 | Black & Decker FP1445 Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
I feel so stupid i can't figure out how to get the food out of my rrkfp650 kitchenaid mixer! help my kale is getting stale. why doesn't it just slide off or twist off?
Most recent food processors have safety features that make it difficult to remove the work bowl. For the Kitchen-Aid RRKFP650, remove the work bowl pusher and cover first. Then you have to give the work bowl a good tug in the clockwise direction - don't be afraid of breaking the work bowl - it can take a little bit of force. If it is still sticking, you can apply a small amount of distilled white vinegar with a Q-Tip to the area between the base and workbowl - in most cases, you won't have to do this.
Apr 19, 2009 | KitchenAid KFP650 Ultra Power 11 Cups Food...
Cusinart little pro plus
I have this food processorfor years and I love it. If you need a copy of the manual go to the Cuisinart website - they have all of the maunals listed there. But, here is the instructinos for the juicer. Good Luck. Using The Juicer
The Citrus Juicer
Attachment includes:
Strainer Basket, which
locks into processor work
bowl. It has grooved cam
on one side and smooth
locking device on opposite
side. In its center is the:
Juicer Stem Adapter,
which fits over motor shaft
of Pro Plus™.
Small cone, for lemons
and limes. It must always
be attached to Adapter
when Attachment is in use.
Slot in center of underside
fits rib on Adapter.
Medium cone, for oranges
and large cone, for grapefruits.
Both fit over small
cone.
1. Place work bowl on Pro
Plus™ base in usual way.
Hold Strainer Basket
open side up, with
locking device facing
you. Align locking device
slightly to left of locking
tab on front rim of work
bowl.
Place strainer basket on
work bowl, fitting Juicer
Stem Adapter loosely
over motor shaft. Turn
basket counterclockwise
as far as it will go, until it
clicks into position.
Turn Juicer Stem
Adapter clockwise until it
drops into position.
Check that it is down as
far as it will go on the
motor shaft.
2. Hold small cone by top
and place it over Juicer
Stem Adapter, fitting slot
over rib on adapter.
Cut citrus fruit in half and
hold cut side down over
cone. With other hand,
hold control lever in
PULSE position and
press down fruit to
extract juice. For continuous
operation, move
control lever to ON. Twist
fruit to extract most juice.
Do not allow juice to
overflow center tube of
work bowl.
To remove attachment,
remove cone from Juicer
Stem Adapter. Loosen
adapter from motor shaft
by lifting it slightly, straight
up. Hold Strainer Basket
on both sides and turn
clockwise to unlock it from
work bowl. Lift straight up.
Remove work bowl from
base and pour out juice.
Feb 03, 2008 | Cuisinart DLC-5 Food Processor
Sunbeam Food Processor/Le Chef 14-11, 14-1A
Check this website: //http://www.householdappliance.com/food_processor_parts.html
Jan 21, 2008 | Sunbeam 4816-9 Food Processor
GE 4 Speed Food Processor Replacement Parts
Take a look on amazon for replacement parts, here: Finally charging for our multi device world I hope I have helped. Cheers
Nov 28, 2007 | GE 106622F Food Processor
Tefal 67610 Kaleo StoreAway 6 Cups Food Processor Logo
Top Tefal Food Processors Experts
Ross Keen
Are you a Tefal Food Processor Expert? Answer questions, earn points and help others
