Question about Car Audio & Video
Havent got full power
Trying to wire up car stereo
  • 44 Answers
Make shure that you buy a wire harness. wire that to you radio matching up the colors. Also may need a dash kit to fit in radio. Plug in the wire harness you bought and slide in dash. Hope this helps you out. good ratings help me..Have a good day
Posted on Jan 13, 2009
Stereo wiring on mk4 golf r32? Fitted new stereo bit radio isn't working I Need to know what colour wire to connect to the power supply for the amplified ariel?
12 volt accessory or same wire that goes to red wire on stereo or cigarette lighter.
OR
What is the current draw on amplified aerial ? or are you talking bout electric aerial(up and down automatically ?) If current draw is really low like 500 milliamp or so then hook her up to blue wire (remote output) on back of stereo but REMEMBER this is LOW current and only meant to switch on amps and raise electric aerials etc.If you think amp on aerial is too much for it then run the rem wire to a 12 volt relay and wire it so that when rem triggers and closes the gate will be connecting an accessory wire OR perm 12v wire to aerial power . That way aerial ONLY turns on(POWERS UP) when stereo is on as opposed to other way where aerial will be powered up every time car ign or acc is turned on regardless of whether the stereo is on or not.
Jun 18, 2010 | Car Audio & Video
Unlock code jeep stereo
you may have to go to the dealer to get it.I had the same problem in my mercedes and they wouldnt give the code to me over the phone or email.also check the books in your glove box.Someone may have written the code down somewhere
Jan 17, 2010 | Car Audio & Video
Cant install aftermarket stereo
The Wht/Blue wire is allways 12 volts; The Ylw/Red is switched only when the car key is on accessories.
1994 Isuzu Amigo Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: White/Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Jan 04, 2010 | Car Audio & Video
Trying to put a new stereo in my holden astra 1989 but the colours on my deck do not match the original colours on car stereo
you should try trial and error, for example test the wires on your car with a power tester and find your power when you do hook it up tp the power wire on your car. after you get the stereo turned on you test your speaker wires with the right & left functions on your stereo and the front and back functions on it untill you figure out wich go,s to wich.
Nov 18, 2009 | Car Audio & Video
2002 malibu wiring diagram?!?!?!?!?!?!
ok, the red and yellow wires serve 2 different purposes.the yellow supplies constant power to your stereo, and the red is switched power. what youve done is combine the two, and connect them to a constant power source. like this, your stereo wont be switched with your ignition. so take off the red wire, but leave the yellow wire connected to the wire its already on. make sure your stereo fuse is good in the fusebox of the car. then, use a test light, with the ignition switch on, to find the second wire on your cars harness that has power. that will be your switched power. connect that one to your red wire, and that will solve your problem.
Aug 04, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Need a wiring diagram
HI,
1999 GMC Sierra Truck Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
please rate my suggestion....
May 22, 2009 | Car Audio & Video
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Illumination Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Apr 29, 2009 | Car Audio & Video
JUST NEED TO KNOW WHAT PIN RECIEVES THE B +
Ken,
Most common for all car Stereo wire color coding are:
Solid RED wire = +12V
Solid Black wire = negative ( - )
Solid Yellow wire = +12V (power ON /OFF) can add additional toggle switch for switching on and off the car stereo
Solid blue wire = Power antenna
the rest of the wires are for car speaker having positive and negative polarity.
note: for the speaker connection wires, all the solid colored wires are positive side (+) of speaker. those solid colored wire with stripe black line are for negative side (-) of the speaker
cheers,
mark
Dec 30, 2008 | Pioneer 12" Shallow Sealed Enclosure,...
I SOLD MY CAR I DISCONNECT THE BACK OF THE RAIDO NOW I DO NOT HAVE THE WIRES FOR PWER, SPEARKS,GROUND,ECT.
What type of stereo do you have? You can try and google that stereo name and put the words "wire connector, or adapter" after it and see what you come up with.. OR.. you may be able to go to wal-mart and check their department for adapters that may fit your stereo.
Oct 20, 2008 | Car Audio & Video
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
