Need keyboard connector clip
I broke the keyboard connector cable clip of my Medion Akoya P6631. Does anybody have a replacement he could sell or know where I could get that clip? I just need the small locking clip that holds the keyboard's cable in place. Thanks in advance!
    Scholar:
  • 156 Answers
It is a hard to find component and not available in a normal laptop spare parts seller. Is that a lift off type or pull back type? If you get an old faulty motherboard in ebay or somewhere, a good chiplevel technician can remove it and solder it to your laptop's motherboard. Otherwise search within ths website for a similar one but if you see one, need to solder it to the motherboard. That work need extreme skill otherwise the whole motherboard will go for scrap.
Link to Site:
http://ie.farnell.com/jsp/search/browse.jsp?N=204062&No=50&locale=en_IE&appliedparametrics=true&getResults=true&originalQueryURL=/jsp/search/browse.jsp%3FN%3D204062%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_IE%26divisionLocale%3Den_IE%26catalogId%3D%26skipManufacturer%3Dfalse%26skipParametricAttributeId%3D%26prevNValues%3D204062
Hope this helps
Posted on Dec 10, 2012
ssebata paul
  • 159 Answers
SOURCE: My Medion Akoya will not boot
reinstall the operating system
Posted on May 23, 2009
SOURCE: Medion MIM2120 Laptop
Remove the large panel (7 screws) on the base of the machine.
The memory is situated under a black flexible plastic cover about 75 x 30 mm - amost directly below the earphone and mousepad area.
Memory is held in position by clips at each side - press them outwards and memory card will pop-up.
A second card can be fitted below and slightly higher than the first.
I have just fitted IGb and will probably put in another (max 2GB), - cost about £15.
Hope this is of use.
Posted on Mar 15, 2008
  • 105 Answers
SOURCE: Broken Touchpad ZIF Connector
Best bet is to obtain a faulty motherboard and use the clip from that - they are often sold very cheaply declared as faulty on ebay.
Please rate my assistance I hope it is helpful.
Posted on Mar 23, 2008
leecom72
  • 4806 Answers
SOURCE: How do I replace a Compaq Presario V5000 laptop keyboard?
You need a flat bladded thin screw driver to prise off the long cover the runs along the top of the keyboard and just below the screen. Make sure you remove any screws at the back of the screen hinges, and along the top above the battery housing (you need a small posidrive screwdriver for this). You will find there is a screw on the underside of the laptop that holds the keyboard in place from underneath, plus two or three very small screws on the top at the screen end. When all the screws are removed you can lift the keyboard up from the screen end and pull (gently) away from the touch-pad end. Tilt it up and you will see the keyboard data ribbon, don't twist it or pull it as you will damage it.
hope this helps
Posted on Nov 13, 2008
  • 3940 Answers
SOURCE: medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Posted on Jan 11, 2010
Testimonial: " many thanks will get it looked at"
Medion akoya
Check to see if there is any debris underneath the keys. Use canned air or an air nozzle hooked up to an air compressor. Sometimes, debris can get underneath the keys, keeping them from depressing the membranes underneath. If that doesn't help, you may need to take it to a technician to diagnose the problem.
Apr 12, 2014 | Computers & Internet
Medion akoya p5300 d hard drive failing i need a replacement
You can buy a replacement anywhere locally that may sell a 2,5" hard drive, or amazon, ebay etc will stock 2.5" laptop hard drives. You must be aware the drives will be blank so you need a way of installing Windows back onto the new hard drive, post back if you need anymore help
Apr 07, 2014 | Computers & Internet
Hi I have a medion akoya p6613 notebook pc The
You need to get the DC socket replaced, or the original one resoldered. Your power supply may be broken, but it is more likely that it is the socket. Check the cable on the power supply for any breaks or floppiness at the joints. (an indication of a broken core)
Sep 23, 2013 | Medion Computers & Internet
Akoya medion split screen
check the screen cable first. as it does not always happen. tilt the screen front and back to see it at some angles the split stop then you can confidently say it's the cable
Jan 03, 2013 | Medion Computers & Internet
Where can I get a keyboard for a Medion Akoya P6512 ?
at http://www.expertech.com.au/medion-akoya-laptop-parts-c-251.html
Apr 30, 2012 | Computers & Internet
The inverter on my Medion Akoya E5312 has broke, where can I buy a new one?
I don't know where are you located but this company could be a great start where you can find your inverter:
http://www.laptop-lcd-screen.co.uk/laptopparts/MEDION-AKOYA-E5312-15.4-LAPTOP-SCREEN_7500.asp
Mar 03, 2011 | Computers & Internet
Trying to get a replacement keyboard for my medion akoya E7212, I phoned medion looking to get one, the tech guy suggested I google it as they dont supply spares. Tried that but no luck, Uk supplier...
Here is a link to medion akoya keyboards for sale on eBay, although none of them mention your specific model. In such cases (I'm a laptop repair pro) I contact the vendor through the "Ask a Question" link under their name and feedback rating and inquire as to matches.
http://shop.ebay.com/i.html?_kw=medion&_kw=akoya&_kw=keyboard
Many Laptop companies have the exact same keyboard supplied on a number of different models.
Good luck.
Aug 01, 2010 | Computers & Internet
Computers & Internet Logo
412 people viewed this question
David Payne
David Payne
