Question about Panasonic DMR-HS2 DVD Recorder
My panasonic dvd recorder dmr-hs2 keeps switching to standby mode
Every time i switch on my dvd it keeps going back to standby mode after 2-3 sec
I have the same problem, but it takes a while longer...just get the circle rotating in the LCD on DVD!
tried unplugging HDD...still does it.
Posted on Sep 28, 2009
Hallo, I'm new here, I hope someone can help me with my problem. I have a Panasonic DMR-HS2 DVD recorder, and I've had no problems yet, till recently. I had programmed several TV programs. W
It might well have crashed!
I suggest you unplug or turn off the power to the unit and leave it off for a while to see if it corrects itself when you power up again.
Keep a look out for any codes in the display when it powers up. Was there a disc in the drive when you shut it down? That might be contributing to the problem if there is.
If the hard drive has failed it still might be possible to remove it and recover the contents, before fitting a new one. There are the same ones you buy for home PC's afterall.
Mar 08, 2017 | Panasonic DMR-HS2 DVD Recorder
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
I want to reset the reorder but i don't know how.
If you do not have your original instruction manual, you can download a free pdf from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-HS2
(right-click and save link/target as... - it is a 3.2MB file (total size))
It may or may not help. Either way it's free.
Apr 25, 2011 | Panasonic DMR-HS2 DVD Recorder
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
On switching on, has single circle spins with dvd led
I had a similar problem with an RCA DVD recorder and I had to replace a capacitor inside the machine.
Jan 16, 2010 | Panasonic DMR-HS2 DVD Recorder
Remote control doesnt work
Go to the manu and try new remote code, Hopefully by changing remote code, from Codeset 2, to code set 1
will solve your problem.
Jan 17, 2009 | Panasonic DMR-HS2 DVD Recorder
DVD Recorder Screen keeps saying HOLD and not switching on
CHILD LOCK:
The Child Lock Deactivates All Buttons On The Unit & Remote Control.
To Deactivate Press & Hold (OK) & (RETURN) Simultaneously Until "X HOLD" Disappears.
Oct 28, 2008 | Panasonic DMR-EH50 DVD Recorder
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
HS2 doesn't turn on
try holding the power on/off button for about 15 sec to power off completely, then push the DVD button. that may work.
Nov 12, 2007 | Panasonic DMR-HS2 DVD Recorder
Panasonic DMR-HS2 DVD Recorder Logo
372 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
