Question about Sony Playstation 3 (PS3) Console
I have a game on ps3 and it's the only one that freezes and it's just not only on mine it also did it one three of my friends and i dont know why kinda afriad to play it cause i dont want to m
I got the need for speed uundercover and it gliches and freezes on loading screens and it does it one three of my friends ps3 too so i know it's not just mine and i tried getting a new disc and it still does it so i havent played it in a while cause i didnt know if it would mess up the ps3 or not so can someone give me some tips to fix this plz?
    Problem Solver:
  • 3 Answers
Try setting your hdmi settings to 720 instead of 1080
Posted on Dec 12, 2012
nliwilson
  • 114 Answers
SOURCE: My PS2 Slim plays music, black and blue discs, but doesn't play silver discs nor DVDs.
Is this a new problem or has your PS2 always had this issue? You cannot adjust the laser at all and are likely to damage it if you try, you can however clean the laser lens with a CD/DVD cleaning disk and you'd be surprised how often this resolves disk read issues. Some of these units did have a production fault that prevented them from reading DVD's, if your PS2 has had this fault since new and/or is under 12 months old you could probably have had it repaired/replaced by Sony but by opening it you will have invalidated you're warranty.
Posted on Aug 09, 2007
SOURCE: psp freezes up and wount play games
the psp has a hardrive and it problyhas blown and need a new one
Posted on Jan 26, 2008
  • 207 Answers
SOURCE: PS3 disc loading problem
This is a dirty or bad bluray drive which seems to be the same as the 3 rings of death for the 360..
Buy a cd laser cleaner and try that if it does not work your laser diode is bad and a new laser is 50$ via ebay.. if you dont want to get to technical then you can buy a drive for 120ish and switch them out.
Sony will charge 150$ + to fix it other then that there is no way around it.. and I believe you need a proof of purchase to get the warranty. I really hope the cd cleaner works but if not then your stuck...
You can sell it on ebay and if its a 60gb you can get about 200 for it... then buy a like new 40gb ps3 for 300ish I have seen just consoles sell at 290 incl shipping. Best of luck!
If you are happy please feel free to rate me THANKS!
Posted on Jul 01, 2008
  • 10 Answers
SOURCE: Cant to get a friend to join online playing Smackdown vs Raw 2008
There is usually two reasons for this.
The first one is the game is just having server problems.
The second one is usually the problem and that has to do with your router settings causing you to have a 'NAT Type 3' connection which can cause connection issues with other players.
Having a closed or limited NAT on your gaming console will cause a variety of issues. Similar to strict, moderate or open on an Xbox 360, the PS3 offers Type 3, Type 2 and Type 1 NAT results. These break down as follows:
Type 1 - Connected directly to the internet (no router/firewall). Should have no issues.Type 2 - Connected through a router properly. Should have no issues.Type 3 - Connected through a router without open ports or DMZ setup for PS3. Everything should function properly, but you may have connection, voice chat or other issues.While most everything will function properly regardless of what your NAT setting is, your best bet is to set up your PS3 so that you can obtain a Type 1 or Type 2 NAT. Since most of us have routers at home for connecting multiple computers or devices to the internet, chances are the best we will get will be Type 2. Thankfully that's fine and everything will work properly.
If you have not adjusted your settings on your PS3 or router, chances are you have a Type 3 NAT and probably never knew it. With a few simple changes you too can have a Type 2 NAT. Order now for just $19.99. But wait, there's more. joker.gif
The first thing you will want to do is check your network connection. Head on over to the Network Settings tab on the XMB. It looks like this:
Once there choose the Internet Connection Test item. It looks like this:
You will receive a warning letting you know that you will be signed out in order to perform the test. Choose okay. If you have not made any setting changes in your PS3 or Router, chances are you will receive the following message:
The warning reads: "When the NAT type is type 3, chat or the communication features of games may be restricted. For more information, refer to the online instruction manual."
If you run the test and have Type 2 or Type 1, stop fooling around and go play some games! If, however, you have Type 3, read on for help on opening up your NAT.
In order to open up your NAT on your PS3 you will need to make an adjustment on your PS3 and on your router. First you will want to set up your PS3 for a static IP address. This means turning off DHCP and assigning your PS3 a single, static IP address. Before you start this process head over to the network tab on the XMB and choose "Internet Connection Status." From here note your current IP address, your subnet mask, your default router and primary and secondary DNS settings. Write these down, you will need them in the following steps.
To do this, visit the Internet Connection Settings tab on the XMB. It looks like this:
From here most of the settings can simply be passed through with default settings. There are two areas, however, that you have to change. The first is choosing a Custom address setting (instead of Easy).
From here, you will want to choose Manual IP Address Setting:
Remember the settings you wrote down from your status page? You will need them here. You will have to enter in the static IP Address you want to assign to your PS3, the Subnet Mask (which is usually 255.255.255.0), the default router (the IP address of your router, most often 192.168.1.1 or 192.168.100.1), and the Primary and Secondary DNS settings. You will have to input all of these numbers. This is made much easier with a DVD Remote or keyboard.
Please NOTE - You will want to set the last number of your IP address high enough that other wireless or wired items on your network will not be assigned the same number through DHCP. While DHCP had chosen .3 as an IP address for my PS3 initially, I bumped it up to .23 because I have less than 23 items in my network. If you do not have DHCP enabled on your router, you do not need to worry about this and can simply choose an IP address that does not conflict with your other devices and which is available through your router.
Once you have all of the settings input, press X to save them. Your settings will change and the PS3 will offer to perform an Internet Connection Test for you. If you let it do the test now chances are you will still get a Type 3 NAT connection. Don't fret little bear, we still have one more step.
In addition to making the necessary changes on your PS3, you will also have to open up some ports on your router. The ports you need to open are:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
I have a Linksys Router and my port forward settings page looks like this:
Depending on what type of router you have, your settings page may look different. In order to obtain an open or Type 2 NAT, you will need to open those ports listed above.
You can see in my screen capture that my PS3 is listed with its static IP address that I set above (.23) and that all of the necessary ports are forwarded to that IP address. The X listed items above (.24) are for my Xbox 360 so you don't have to worry about those.
Once you have forwarded these ports and saved your settings its a good idea to unplug and plug back in your router. This will refresh everything on your network connected to your router. Once done head back to your PS3 and perform an Internet Connection Test. If you did everything correctly you should receive the following page:
Congratulations, your NAT is now setup and working properly!
Posted on Jan 09, 2009
flacooo1
  • 172 Answers
SOURCE: Sudden video distortion and game freezing.
well let me tell you what to do your ps3 is about to fail and not turning at all this is the first problem then the second problem is that the ps3 will not turn on at all it will bip every time you will try to turn it on but there is a fix for this what have happen is that the GPU got to hot and now is not making a good contact with all the pin on the bottom of the GPU is sounds crazy you may say what this guy is talking about but believe me do something before it gets worse go to ebay and on the ebay home page enter the word ps3 reflow there you will see 2 guys that do this type of work because this is what you unit needs the GPU needs to be reflow and this will take care of this problem
Posted on Apr 29, 2009
How can i unbock my self i benn blocked frome adding friend i been blocked from adding friend so i want to know how can i unblock myself
you awill need to re-activate your account. or remove your friend or have him add you one of those three are the solutions i found
Mar 25, 2011 | Berkeley Systems, Inc. You Dont Know Jack
Why does my grand theft auto china town wars keep freezing
im sorry i dont know why but most of the games on the R4 do that incuding mine
Jul 07, 2010 | Rockstar Games Grand Theft Auto Chinatown...
This pc freezes out so often and i had to push the power button off and on again less than every hour.
Well, its time my friend to get a new PC. I prefer
www.cyberpowerpc.com it is cheaper than dell, mac, hp, etc. and it will last you MANY years with out being outdated. Mine is three years old and it still has the power to run these games:
Call of Duty 5
Modern Warfare 2 (Infinity Ward employees ONLY please don't ask for a copy of the game)
Oct 18, 2009 | Dell Dimension 4600 PC Desktop
Nintendogs - icons has disappeared!
dont know her friend might of turned it of while it was saving turning the game saved data to scramble :/ u might need to start again sorry :l hope i helped (:
Jun 17, 2009 | Nintendogs: Labrador & Friends for DS
My ds keeps freezing!
try cleaning where the gameboy cartrige is if that doesnt work leave it for a day or two. DONT WORRY. MINE DID THE SAME THING
Jan 08, 2009 | Nintendo DS Console
My new EA Skate freezes my XBox 360
There may be some scratches, not all scratches are visible.
Try taking it to a descratching machine (available at some game shops)
If not, then try returning the game for a new one
Jan 04, 2009 | Microsoft Xbox 360 Console
Getting a friend code
well u need to go on there website and speek to the costemer servis and the will sort it out.
can u help me on mine.ta
Nov 16, 2008 | Nintendo Animal Crossing for DS
WHEN I PLAY MY BURNOUT PARIDISE AND IT FREEZES UP AND YOU CANT DO ANYTHING YOU CANT TURN IT OFF ARE ANYTHING I ONLY HAD IT A MONTH . I BOUGHT IT FROM BEST BUY.
If your talking about ps3 then i've had the same problem with call of duty 4 and three of my friends have had the same problem with call of duty 4 aswell. I dont think its anything to do with the game. Its more to do with the ps3. The game contains alot of graphic detail and the ps3 sometimes gets pushed to far and locks up. I've noticed that my cod4 locks up when i throw alot of smoke grenades. If theres alot of action going on in the game at the time it freezes then thats probably the reason. Theres no real solution to this problem except maybe sony will come up with an update that solves it.
Mar 21, 2008 | Video Game Consoles & Games
Animal crossing freezing while playing on ds
It's probably the game since it does the same thing to me.
Jan 12, 2008 | Video Game Consoles & Games
Game freezes after 5-10 mins play time
if when it freezes it has a kind of checkerboard pattern, then it is what happens before the three red lights of death, try the eraser trick posted by Carl26
Aug 29, 2007 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
