Need a power adapter - Computers & Internet
  • 5 more comments
  • Amy Bouvet Dec 11, 2012
    That is a good idea, as long as the power cord on the new one fits the one I have because I need to get the data on the one I have!
  • Chris Dec 11, 2012
    Your best bet is to call Cintre and it shouldn't be an issue at all to get you a power supply for it as long as you give them the name and model you gave me.
    ok THANK YOU!!!
    No problem.
  • Amy Bouvet Dec 14, 2012
    I am sick about this....I took the drive to Best Buy and bought a new backup drive so they could transfer all the data from my ezstore drive onto the new drive....they told me that they could not retrieve the data in their normal way, they would have to send the drive to a specialist and it would cost $1000. or more. :(
    I guess I will never retrieve all the data on the ezstore back up unit. Thanks for your help tho.
    They told me that buying another ezstore unit so I could get the power cord I needed would not help because something is wrong with my drive.
    Novelist:
    Champion:
  • 233 Answers
You may order a laptop charger from a prefessional laptop adapter online store. Usually they provide all brands of laptop power adapters with cheap price and a year warranty. Just use your laptop model or your original charger part number to find the correct charger:
http://www.chargerbuy.com/
Posted on Dec 13, 2012
  • Chris Dec 13, 2012
    This is for an external drive, not a laptop.
    Problem Solver:
  • 13 Answers
Maybe give us the model of your machine? We can't read minds here.
Posted on Dec 10, 2012
  • 4 more comments
    It is a cintre ez store external backup drive. Model # CI-345U2
    That wont' be too easy to find. Have you tried contacting the manufacturer directly? If not, you can try that, they can send you one if you pay for it. You can also make one yourself. Look on the device where the power plugs in, use that information to find a comparable power supply. See this link: http://images.highspeedbackbone.net/item... note that the power input there is 12v. If you still have your old one and it just doesn't work, find another power supply with same volts and amps, and wire that end on it, but you must get the polarity right or it will fry the unit. Very important
    actually if you aren't very electronic savvy, I wouldn't attempt to make your own cord
    Nope, I won't be making one myself! I did check at the manufacturer and did not see an option to purchase the cord. Can I just go buy a 12V power cord at Best Buy or a computer store?
    I can not find the one that came with it.
    You will need to email or call them. This will be a special request item that they should be able to get to you for a nominal fee. I also seen they appear to be around 30 to 40 bucks online. Maybe just buy a new one?
    Problem Solver:
  • 15 Answers
Google: Manhattan 70W Universal Laptop Power Adapter with Automatic Adjustable Voltage
Posted on Dec 11, 2012
Power problem power is not on
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, your compaq f500 power adapter is probably faulty and needs replacement.Hope this helps.
Jan 30, 2013 | Compaq Presario F500 Series Laptop...
I have Acer Aspire 3680-2022 notebook. I still have power instability after buying a new a/c adapter & new battery. When a/c plugged in, battery can randomly & rapidly drop...I get a lot of...
Hello.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 03, 2011 | Acer ASPIRE 3680-2022 Notebook
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
WILL NOT CHARGE OR POWER ON
Normal 0 When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Oct 22, 2010 | Acer Aspire 5100 Notebook
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
No power at forward poser adapters
did you check the fuse (under the hood) to see if it needs replacing? I had a dime roll into my power adapter which in turn blew the fuse. It is a separate fuse than for the rear power socket(s). Check the owners manual for the proper location for the power adapter (front). Remember to check the power adapter for any metal objects before changing the fuse.
Jan 05, 2009 | 2006 Buick Rendezvous
POWER ADAPTER
LOST POWER ADAPTER NEED TO PURCHASE NEW ONE
Apr 30, 2008 | TruTech PVS12701 Portable DVD Player
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
