Question about Maytag MGC5430 Gas Cooktop
Maytag gas dryer, ignites and then shuts off after 5 seconds
    Sergeant:
  • 475 Answers
Are you sure you don't have the cord all in a ball or check to make sure your getting gas there.
Posted on Mar 11, 2013
What wood cause a burner to ignite and will not turn off.
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Oct 10, 2014 | Whirlpool Kitchen Ranges
Maytag MGR7775WS igniter does not work
time for a new igniter, you can order it at marcone.com All you need is a model number
Oct 17, 2012 | Maytag MGR7775WS 30" Self Cleaning...
Maytag/Jenn Air JGD8130ADS one burner will not ignite but all others will. solutions?
Turn off gas. Remove the cartridge and remove back cover. Clean the ignition spark area. Re-install the cartridge without the back cover. Try to ignite the spark. If the spark works. The spark wire is too close to the back cover. Use an electrical tape to insulate the wire from the back cover. Other swap the two spark to see if you have a faulty spark.
Jan 02, 2012 | Maytag JGD8130ADS 30 in. Gas Cooktop
I have a cookto maytag mgc5430 and the ignition clicking wont shut off i have to unplug stove for it to stop
Hi zwerling,
Moisture or water have come into contact with your ignition devices, they just need to be dried.
Please follow my directions on the Tip below on how to do this:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 07, 2011 | Maytag MGC5430 Gas Cooktop
2 burners wont ignite
Hello there:
A burner doesn't work The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite. The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
Jun 29, 2010 | Thermador SGS36GS Gas Cooktop
The ignite spark will not shut of ! what can I do?
Clean all grease and stains off the igniters and dry them with a hair dryer.
Mar 12, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Maytag clothes dryer flame won't stay lit
Usually this is the two gas valve solenoids, though it can also be a bad flame sensor or thermo. The solenoids are easy to change, they are right in front and usually have two screws holding them down. Order new solenoids by model number. Once you have the new ones you will see how they look and where they go on your gas burner. Just make sure you make not of the wire positioning and install the new ones the same way. Usually 3 wires on one side and two wires on the other. Parts are pretty cheap. Before I replace these I put an electrical testor on the solenoids to test if there is 120 volts coming in when the burner stops working. If their is 120 volts and the ignitor is glowing then you definitely have bad solenoids. Good Luck, Appliance Specialists.
Dec 15, 2009 | Cooktops
I cleaned the gas top and the two left side burners do not ignite
Take the burners out, then take a needle and stick in the small hole where the gas comes thru.
Jul 15, 2009 | Maytag MGC5430BDS Gas Cooktop
Igniters on my Maytag gas cooktop do not spark
u nid the serviceman to replace the ignition coil,coz its hard to replace & expensive the parts,temporary use macth
Jun 27, 2009 | Maytag MGC5536 Gas Cooktop
Jen-Air Gas range Igniter keeps clicking but not starting fire
01/26/09 My wife decided to give our Jenn-Air a good cleaning. With lot's of soapy warm water she pulled the knobs off and washed under each of them not realizing excess water was now running down the inside of each control knob shaft. The igniter immediately began clicking away as it was being shorted by the conductance of the water now inside of the switch. I had to remove the cover (2-screws) to access the control switches but that is all I needed to do do in order to have clear access. Using her hair dryer it took about 5 minutes of warm air blowing down each of the shafts until the water evaporated and the clicking stopped. Wahla. The old Jenn-Air is back to working order again.
Sep 22, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Maytag MGC5430 Gas Cooktop Logo
67 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
