Posted on Dec 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Deskjet 1056 supposed to be dual voltage...?
I just bought an HP Deskjet 1056, which is supposed to be dual voltage according to the specs, but the sticker on the box says "Power: 120V". I'm hoping that is only because it was purchased in the US so the power cord in the box has a 110v plug on it. Will I be able to use this in a 220V country with just a plug adaptor? I bought this model specifically because I want to take it overseas with me. If it's not really dual voltage, to where I can use it over there with just the plug adaptor, then I will need to return it, and I only have 10 days in which to do that, so please help ASAP!
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Dec 11, 2012
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1013666
Points
21773
What does it say on the "brick" on the cord? Look for power specs on the cord transformer.
Testimonial: "It's got ~100-240v! Now WHY didn't I think of that?!? Thanks, Max! Unfortunately, I'm going to have to return it anyway, as I received it with the one side of the input tray's attachments broken! I already had an HP Deskjet F4440 (which was also dual voltage) that recently stopped recognizing the color ink cartridge (regardless of ALL the troubleshooting steps being done multiple times!) after the warranty ran out. I finally, just now, paid for a trouble shooting call (which they are refunding, having determined that the color print head must have gone bad - YAY!) and I ended up letting myself get talked into buying a discounted/refurbished HP Deskjet 3050A to replace the F4440 (which was why I'd bought the 1056, but since it arrived broken...)... I HOPE this will be the END of my nightmare, as I am moving overseas toward the end of January and need to ship my printer when I leave! Thanks again for the oh-so-obvious-DUH! reminder/solution, Max! ;-} "
  • max carson
    max carson Dec 11, 2012
    Sometimes we over think a problem. Everyone does it, few admit it. Cheers! Happy Holiday to you and yours.
2 Related Answers
PrintDocta
  • 217 Answers
  • Posted on Apr 05, 2010
SOURCE: changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
pankaj_dic
pankaj rautela
  • 1252 Answers
  • Posted on Sep 29, 2008
SOURCE: 110v plugged to 220v
your adapter burnt out, its better you bougth a new one
How do I rotate a document I have scanned onto my HP deskjet 1056
just open picture with microsoft picture manager there is option to rotate
Don't know where the print head is located. All that I see is cartridges on my hp deskjet 3847.
Hi Dear,
HP Deskjet 3847 is a inkjet dual cartridges base printer there is nothing like print head.
Print heads are only in Dot Metrix printers.
Ok for more description about hp deskjet 3847, you may see the manuals from following links..
Manual1
Manual2
I hope it is usefull..
Have a hp deskjet 3940 lost power lead? its in spain in a caravan but i have written down +15V +32 V AND ITS 3 PIN HOPE YOU CAN HELP GOING BACK SUNDAY
Hi.
The adapter is a +32V 563mA +15V 533mA dual-voltage outputusing a 3 pins conn.
Part number is 0957-2119 (Espana) or 0957-2119.or 0950-4397.
Here the part from HP:
0957-2119
The best way to get the part is contacting HP support and parts. Here HP parts Europe.
Here a seccond hand offer.
1helpful
Is a HP Inkjet Print Cartridge 94 compatible witha Hp Deskjet 6940
Not according to the HP site.
It shows 96, 97, 99, and 100.
Go to: HP DeskJet 6940 Supplies
Thanks for using Fixya.
Hey, I have a hp zd8000 netbook with an ati mobility radeon x600 128mb video card i would like to know if i can run cod4 on it thx.
According to this you can't.
X600 Specs:
http://ati.amd.com/products/mobilityradeonx600/specs.html
COD4 System Requirements
Recommended requirements:
CPU: 2.4 GHz Dual Core or better
RAM: 1GB for XP and 2GB for Vista
HD: 8GB Free Space
GFX: 3.0 Shader Support, Nvidia Geforce 7800, ATI Radeon X1800 or better.
Minimum requirements:
CPU: Intel® Pentium® 4 2.4 GHz, AMD® Athlon™ 64 2800+ processor
or any 1.8Ghz Dual Core Processor or better.
RAM: 512MB RAM (768MB for Windows Vista)
HD: 8GB Free SPace
GFX: NVIDIA® Geforce™ 6600, ATI® Radeon® 9800Pro or better
HP Vista Won't accept software program.
According to this link from HP Vista only has a basic driver built in. There should should find information for installing the printer.
Hope this helps. Please remember to rate this information.
Thanks
Toolbox utility
The HP Deskjet 1280 doesn't appear to have a toolbox utility at all, especially for Vista, there's even less.
How are you supposed to check the ink levels without such a utility?
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
k24674
ADMIN Andrew
ADMIN Andrew
