Question about Home Health Pacesaver Boss 6 Series Heavy Duty Power Wheelchair
I have a Pacesaver Boss 6 & my tire separated from the drive wheel . I hear this is a common problem & need to know if Pacesaver manufacturing can replace @ no cost to me.
I purchased it in May of 2009 . I live in a nursing home & only get $35.00 per month personal allowance, the nursing home gets the rest . So since this is a common problem I hoped it would be covered by warrenty. Please contact me @ sundayg52@gmail.com & let me know either way.
  • 1 more comment
  • Sunday G. Good Dec 13, 2012
    The price I was quoted for the tire/wheel assembly is $257.00 for one & $666.for two. i can't just get one beccause they no longer make the 12 inch . Because of this problem they switched to a 13 inch .If the company won't replace it then I need an organization to purchase them for me or maybe you know someone that has them used for a reasonable amount . If anyone can help they can deal with the nursing home I'm in or purchase them & ship to me at the nursing home. The maint. man will put them
    The tire/ wheel size I need is 13 x 3.00 -4 & the serial # is 904169FFBAGK. The chair is Pacesaver Boss 6
  • Sunday G. Good Dec 19, 2012
    aftermarket didn't have the tire/wheel assy. But thanks for trying to help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 104 Answers
Try "the aftermarket group" on the www and get the maint man to do it
Posted on Dec 18, 2012
Latitude. How can I replace control arm and ball joint assembly?
Lower you can do fairly easy. Upper, a bit tougher.For the upper you will need a spring compressor.
Mar 21, 2016 | 2011 Jeep Patriot
Can't remove the rear wheel from a cox lawn boss
it is common for the rear wheels to get stuck to the axle i just change the tires or add a tube while its on the axle you will damage more trying to get them off
Sep 30, 2012 | Garden
It will move side to side But it has no forward and reverse and the batteries are brand new
contario With little information other than what you are telling me your problem seems to be the joystick. If the chair's joystick will make the motors turn your chair but won't go forward or back then the problem is in the joystick and will have to replaced. Sorry hope this helps
Oct 26, 2010 | Home Health Pacesaver Boss 6 Series Heavy...
My scooter is making loud clicking sounds as though something has come loose & hitting something in the rear wheels as it goes around. The repair tech rotated the rear tires last week & this helped...
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
Jun 29, 2010 | Pride Go Go Elite Traveller Plus HD 4...
My front end makes a loud humming noise. At low speeds, I hear a humming noise and at high-speeds I can hear a noise in my tires. Not sure if it is an the wheel bearings, bad tires, or alignement.
Alignment will not create a sound by it's self. The most common cause of humming (especially if you have an agressive tread design)is a wear pattern in the tires...check for that or rotate the tires around & see if the noise changes. If it does then you know it's in the tires. & Not always, but most of the time a bearing noise will increase or decrease in intensity if you load up one side at a time by doing 35-50 mph & turning slightly to each side.
Sep 25, 2009 | 2003 Ford Explorer Sport Trac
When i go over 55mph my front end trembles so bad it can be felt on the steering wheel
There are multiple reasons the front end could be shaking.
1. Tires are out of balance or one has become separated causing a knot.
2. One of the front bearings is going out.
3. One of the 2 front cv drive shafts are wearing out or bent.
4. Inner and Outer Tie rod ends needing replaced
Above are the 4 main causes of vibration in the front end being able to be felt in the steering wheel. i would first take the vehicle to the tire shop and have them check the balance on all 4 wheels. Also, while they have the wheels off, ask them nicely if they could check out the front end for you.
Sep 12, 2009 | 1996 Nissan Maxima
Front end vibration
Have the tires been balanced? this can also be caused by a defective tire cord, it is called cord separation.
May 29, 2009 | 2004 Cadillac Deville
Home Health Pacesaver Boss 6 Series Heavy Duty Power Wheelchair Logo
98 people viewed this question
Top Home Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Home Health Health and Beauty Expert? Answer questions, earn points and help others
