Question about GE Spacemaker JVM1640SJ Microwave Oven
Vent motor turns on, but does not draw air in as it should...
Hello, I purchased a condo with a GE spacesaver model # JVM1650SH01 over the range already installed. the microwave is approximately 2 years old, but since the day I moved in a year ago, the vent does not draw in air as it should. I can hear the motor running fine and it is a upward outside exhausting vent. What could be the problem? I recently purchased a bosch unit for my previous condo and I recall there was a vent flap that needed to be swapped to go from a counter top to over the range...does this have something similar? thanks for the help in advance!
  • iwantwu Jan 13, 2009
    Ok, I just removed the microwave from the wall and saw that the block plate was on the back and the fans are blowing correctly out of the top of the unit. but the suction from the bottom of the microwave is so weak, that it doesn't even vent steam from water.
    is there anything else that I could be overlooking? or are these exhaust fans just that weak? my filters look brand spanking new!
    thanks again!
    Problem Solver:
  • 14 Answers
The vent tube in back may not have been changed over they can be vented or ventless but you must switch the flap in back you had the answer in your question ... good job,,..lol
Posted on Jan 13, 2009
  • grandpasteve Jan 14, 2009
    the fan should not be that weak has the fan been reveresed .. remove the filters and see if that helps i will look at some schematics later and see if i can find anything else.. the fan could be weak and need replaced..
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
How do I convert the exhaust on a GE spacesaver microwave to vent out of the top
Take it apart and move the metal panel that blcks the air for going up to the back.
Sep 20, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver JVM140J 001, intermittent Vent Fan on Low
see the next steps for fix it, use the common sense.God bless you
First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start
Aug 03, 2012 | Microwave Ovens
The turntable on my GE spacesaver xl 1800 stopped turning. The model number is JVM1850BH01 I would appreciate any help.
On this model, the power to the turntable motor ("drive motor") is supplied by a tap (outlet terminal) on the internal cooling fan motor.
The other side of the turntable motor's power is switched on and off by a relay on the control circuit board.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
If the cooling fan is running, but the turntable is not, then it's probably a relay issue or connection which we can repair.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 30, 2011 | GE XL1800 1100 Watts Microwave Oven
Ge space maker Ge model jvm1650sh01.  Serial hg
It may be a defective upper or lower door switch (or either switch's mount may be bad) or a stuck relay on the control circuit board.
Our file on door switches is here.
After you or a friend look that over, if you still have a problem, we repair these control boards for $39.95 with a one-year guarantee.
Instead of having yours repaired, you can buy a new control circuit board from the Pros here, our favorite supplier.
Jul 07, 2011 | GE Microwave Ovens
Ge jvm1650sh01 surface light doesnt work/ vent
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | GE JVM1650 1000 Watts Microwave Oven
HELLO, On my built in over the range ge profile
http://www.geappliances.ca/jsp/ge_Listing.jsp?product_id=13&cmb_378=---&cmb_Colours=---&cmb_421=---&cmb_Brands=3&cmb_379=---
click on the link above and it will be able to supply you with your manual. It also has contact information so you can call toll free to ask your question.
1800-626-2000
Dec 06, 2009 | GE JVM1840 Microwave Oven
GE Spacesaver microwave table wont turn
either your turntable motor part# WB26X10037 G.E. is bad or the motors capacitor part# AP2026076 is defective they are both the same price
Oct 08, 2009 | GE JVM1440 Microwave Oven
GE microwave not heating lights and keypad functional
You may have a fuse blown on the micro/ the vent and lights are a diffrent cercut , Try replaceing the fuse. its on the in side of the unit. if you need further assitance and you think you can do this I will be happy to instruct U DFD
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1790 Microwave GE-Draws air from bottom and top vents
1. You have to have exhaust pipe to connect m/w vent and this pipe has to be free from obstruction.
2. If it already connected and good, but air come from vent bar over door, then blow motor on top of the m/w was installed in wrong position ( motor has 2 -3 position depends which way air coming out up, back or front).
3. In this case you have to remove m/w from installation and change motor position.
Dec 10, 2008 | GE JVM1490 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
340 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
