Question about Garden
WHAT TYPE OF OIL DO I USE ON MY TRANSAXLE MOD 917.273080
I HAVE A CRAFTSMAN GARDEN TRACTOR YR.2000,I CHANGED THE OIL FILTER ON THE TRANSAXLE AND KNOW ONE SEEMS TO KNOW WHAT TYPE OF OIL TO USE AND HOW DO YOU KNOW WHEN IT IS FULL? ALSO WHERE IS THE FILL PLUG.
  • 2,239 Answers
Hydrogear transaxels take a multi grade oil 20-50 the filler is a brass plug on the top, there should be a 1/4" air gap at the top to allow for expasion, Tuff Torq units also take a multi grade oil 10-30, these units normally have a resevoir on the top with upper and lower fill marks.
Posted on Dec 11, 2012
  • 246 Answers
SOURCE: Changed transmission filter but don't know how to
Hello:
I can Assist you, but I Require the Model Numbers Off the Unit and the Hydro Transaxle Tag.
With these I can Locate the Correct Manuals and Better Assist you.
I have Just Joined this Site as an Expert.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
huffman49
  • 235 Answers
SOURCE: Lawn Tractor 1000, oil chg
there is no filter. but when you drain the oil. start by adding a 1/4 quart and check the level. if still low keep adding (little at a time) until it reaches the full mark on dipstick...good luck
Posted on Apr 11, 2010
  • 63 Answers
SOURCE: Changing the oil filter on a lawn tractor
If it is a screw on type oil filter, apply a film of oil on seal, then screw on. If you want to, go ahead and pour some oil in the filter, in my opinion the oil will circulate faster if there is some oil already in the filter.
Posted on May 12, 2010
SOURCE: Craftsman DGS6500 Garden Tractor 24
It means change the oil. It will come on every 50 hours regardless when the oil was last changed, then go off after a few hours.
Posted on Dec 10, 2010
LEAKING OIL right transaxle
Johnny, Transaxle needs a new seal. you can get or order your seal from any local small engine repair shop. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TORO Wheel Horse Hub Removal and Transaxle Seal Replacement
Replacing oil seal on rear axle of Lawn Tractor 917 288250 ShopYourWay
2007 Craftsman 917 287210 Lawn Tractor with leaking Transaxle
Rebuilding lawn tractor transaxle Part 1 of 2
lawntractor transaxle seal Google Search Ord
Aug 25, 2016 | Garden
Will a toro rear end work on a craftsman 42 in?
I'am not sure,but a Craftsman tractor has a Peerless Transaxle,model # LTH2000. You didn't say,if the tractor you have is a manual transmission or a transaxle type.I will say this,that at Craftsman,they usually have their own brand of transmissions. Another brand might not be adaptable. I know this answer,may not be what your looking for.There is so many,ways a transmission can be installed on the different,brand of tractors. I would call Sears,and ask them,if a Toro would adapt,to a Craftsman tractor,you might get lucky. Sincerely,Brad Locke 11/23/15
Jun 26, 2015 | Craftsman Garden
I have a craftsman 24hp model # 917.28970, how do one change/add fluid to transaxle or change. Is a filter required, and if so, which one? What type of oil is required. r
The fluid has been added to the transaxle,at the factory. You do not have to add or service it for the life of the tractor. That is unless,you have removed the transaxle and repaired it in some way. I don't know if this is a new tractor or not,if it is and you are having a problem with the transaxle,and is not working correctly. Try this,Sears fix to this situation is: Move the tractor forward about 5 feet then move it back 5 feet. What this does is,to eliminate air trapped in the transaxle. Sears,claims this may take several times. Why they didn't do this when they first serviced it,is anybodys guess. I'am late in answering your question,anyway i hopes this helps. It you have an Owners Manual,it will state this procedure in your manual. B. Locke
Jun 25, 2015 | Craftsman 42" 24hp Turn Tight Hydrostatic...
How do you add pump oil and transaxle oil to transmission on craftsman mower 917.289140?
These are sealed transaxles and normally don't need oil added. There is a vent cap where oil can be added but this is normally done when the transaxles are being repair while removed from the mower.
Feb 04, 2015 | Craftsman Garden
Tansmission oil type for model# 917.254740
Your Craftsman is equipped with a Agri-Fab transaxle, the predecessor to the Hydro-Gear brand. The recommended oil is 10w-30. Unfortunately, the transaxle on your craftsman tractor is not serviceable. It is sealed for life. The only way to change the oil is to remove the unit from the tractor, tip it upside down and drain the oil out the reservoir plug.
Jun 16, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Hi, I have a Craftsman Garden Tractor 18HP Twin, model mo. 917.255919 that has a transaxle leak. The transaxle takes about 5 quarts of SAE 30 Motor Oil. I took the transaxle apart last summer to fix a gear...
I would drain transaxel out and refill with 80w90 gear oil. I think the 30 w is way to thin. You can try some lucas trasmisson sealer and conditioner and see if that helps.
If you have to remove the transaxel I would use hi-temp silicon sealer to seal all seams and arou
nd axel shafts. I have a six year old craftsman garden tractor 18 h.p. twin mod.number 917.2722751 and I'm nearly sure it uses the same transaxel so if you do have to get into the transaxel the oil seal part number is 788088A.I can not find the suggested quanity of oil but I just fill to top thru oil fill plug on top front of transaxel.Hope this helps you. Thanks
Jun 22, 2011 | Garden
Apr 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Changed transmission filter but don't know how to get oil back in to Craftsman Garden Tractor.
Hello:
Good Luck
Respectfully
John
May 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman II mowre oil capacity and filter type
The outstanding Briggs opposed twin engines have an oil capacity of 1.5 qts. The recommended oil is 10w30 full synthetic and 50 hour change intervals. Some engines were equipped with an oil filter, if so, the capacity is 1.7 qts. fantastic engines, take care of it.
Mar 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Change hydrostatic transmission oil
we have tractors and, yes any of those drain bolts will work (for best results do both) then after its drained, put the drain bolts back in and top up the level
Oct 27, 2008 | Husqvarna Garden
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
