Question about ASUS U47A-BGR4 2.8GHz 750GB 14" Laptop Refurbished ASU47A-BGR4-S i7 14"
Can i upgrade my asus u47a with 2nd gen i7 processor to 16gb ddr3
2nd generation i7 hd3000 graf.
  • markveach
    markveach Dec 10, 2012
    or can i upgrade the processor to a 3rd gen
  • ASUS Master
  • 27,725 Answers
Each computer contains two important components---a Central Processing Unit (CPU) and memory chips. The CPU and memory chips work together to process computations within your computer. You can't have one without the other. Your computer has a base amount of memory installed, 512 Megabytes or higher, that can be expanded to beyond 1 Gigabyte, in most cases. Before you upgrade your computer's memory, you need to know what type of RAM your computer takes: SDRAM (Synchronous DRAM), Rambus DRAM (RDRAM), DDR (Double Data Rate SDRAM) or other type.
Open your computer's Internet browser by clicking on the program's icon on your computer's "Desktop," this applies to both Windows and Mac platforms. Enter www.crucial.com/systemscanner/index.aspx in the URL box at the top of your browser's screen. The "Crucial System Scanner" tool application website will open. Click on the check box next to the wording "By selecting this box and clicking the download the scanner button, I agree to the Terms and Conditions." Click on "Download the Scanner." The "Opening CrucialScan.exe" dialog box will open. Click "Open" or "Run" to download and set up the program directly. Click "Save" or "Save As" to save the program's setup file on your computer if you don't see the "Open" or "Run" option or you are using dial-up or a slow Internet connection. The program will download and setup on your computer if you selected the "Open" or "Run" option. Navigate to the directory where you want to save the file, if you selected the "Save" or "Save As" option. Select the "Desktop" if you have a hard time locating downloaded files on your system. Double click on the "CrucialScan.exe" icon to open the program, if you selected the "Save" or "Save As" option. Click "Run" when prompted with the "Open File -- Security Warning." The "CrucialScan.exe" program will run and appear in your computer's Internet browser. Scroll to the second section on the "Memory upgrades from Crucial.com -- Determine My Memory Needs" website. The section is labeled "Your XXXXX Specifications." The "XXXXX"s represent your computer's brand and model. Locate the wording "Each memory slot can hold..." Write down the this sentence on a piece of paper---this is the type of RAM your computer accepts. Click "File," "Print," "OK" to print this website, if you have a printer attached to your computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible Hope this helps.
Posted on Dec 11, 2012
Is it possible to upgrade the processor for the sony vaio pcg 81114l
most likely this cannot be done, the sockets for the processors have changed twice since then. I don't think you would see a great prefprmace change if you could. You might thim=nk about upgrading to a more powerful core I7 from that generation, but you would need to find out which mother board you have and which processors it supports. Unless you are skilled in laptop repair, I would pass on the upgrade.
Nov 13, 2014 | Sony VAIO Computers & Internet
How do i open the cd drive
go to help AND WRITE IN SEARCH OPEN CD DRIVE
Sep 17, 2014 | Dell XPS 8700-3751BLK Desktop PC with 4th...
Computer don't start,
If it doesn't start at all, check motherboard for a short by unplugging the processor power cable (4 pin normally), and turn the computer on. If the fans start rotating, it is probably a short. If that isn't the problem, check for cables that should be connected, and test the processor in another computer. Hope it works (it did for me)
May 27, 2014 | Powerspec G213 Desktop Computer; Intel...
Hard drive beeps
was your vostro 230 third generation? meaning, did it use DDR2 memory before or always had DDR3? They are not compatible. 2nd generation computers cannot use third gen parts. cpu, ram, most none of that type stuff. the motherboards are different and cannot change. if it was ddr2 memory you have to use ddr2, not ddr3, hope that helps.
Nov 19, 2013 | Dell Vostro 230 Safe space Tower w monitor...
Upgrade proccessor
Dear Justin,
The Latitude E5410 service manual shows that the following processors can be used: Intel Core i3, i5 and i7 series, as well as Intel Celeron and it is also shown in the manual that the processor can be removed (it is not soldered directly to the motherboard) . And a review of this laptop by "Notebook Review" indicates that "The Latitude E5410 offers a wide range of processor options, spanning from the Core i3 370M to the Core i7 620M."
Although I do not know which processor you presently have in your laptop, I would say that it can be upgradeable from a Core i3, or Core i5 to a Core i7 620M processor.
Hope this helps!
Regards,
Miguel L. Martins
Nov 02, 2013 | Dell Latitude E5410 Laptop Computer PC...
I want to upgrade the cpu to a newer (possibly 3rd or 4th generation) processor. Does anyone know what's the latest compatible processor with the ASUS N53SV-B1? Will I need to upgrade or convert anything...
ASUS: English Speaking* System Product Support:
1-888-678-3688
Available 24/7
All-in-One, Desktop, Netbook, Notebook, Nettop, or Tablet
* Contact availability subject to change at any time without prior notification. Closed in observance of major national holidays
SUGGEST THAT YOU TALK TO ASUS THEMSELVES.
Aug 18, 2013 | ASUS N53SV-B1 - N53SV-B1 15.6" Led...
Upgrade cpu on n53sv-b
The N53SV supports intel Gen 2 processors. The fastest one you can purchase is i7-2920XM
Backlight type for asus u47a-Rs51
You can get a CCFL lamp from this WEB site.
LCD screens and Inverters www.lcdparts.net
Jan 22, 2013 | Asus Notebooks ASUS U47A-RS51 14.1" Laptop...
Why my computer show only 4 core? core I7+Asus p6t7
an i7 processor only has 4 cores. It has a technology (hyperthreading) that makes the computer think that it is running 8 cores, but it only physically has 4 cores. Hope this helps. If you have any other questions feel free to leave a comment on this post.
Sep 14, 2011 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
I have a Asus P4GE-MX motherboard with processor P4 2.4 GHZ having pin, now i want to change only my processor which should have more effectiveness than P4 &having the same motherboard
You will not find a better processor or replacement parts, this system is too old and parts are not being made. Newer systems are 4 generations better and prices are heading down, buy a new system with Intel CORE or CORE2 chips or the latest I3, I5 or I7 chip using DDR3 memory. DDR4 will be arriving in 2012, prices on old DDR3 will continue to go down.
Feb 04, 2011 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
ASUS U47A-BGR4 2.8GHz 750GB 14" Laptop Refurbished ASU47A-BGR4-S i7 14" Logo
533 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
