Question about Dell Inspiron 1200 Notebook
Can you blow out the dust in you lap top yourself
    Problem Solver:
  • 11 Answers
yes, if you have an ordinary vacuum cleaner, then you can.
Simply attach the end of the hose to the part of the laptop where you can feel with your hand how the cooler blows out.
Please note that in order to avoid static electricity it is required that the laptop is turned off and the battery is taken out.
Good luck.
Posted on Dec 10, 2012
My lap top Computer keyboard keeys leep sticking
it might be dust effect or inside the rubbers got over its life time.. clean it or change the keyboard..
Jan 31, 2014 | HEWLETT-PACKARD Computers & Internet
Unclog my Toshiba lap-top
get a blower >open the back cover of the hard disk or ram > blow the dust and close it will be ok, if not then get a qualified tech to open the laptop and spray the fan with a non-corrosive detergent or replace the fan.
Sep 30, 2013 | Toshiba Computers & Internet
Power cord won't power charging of lap top
take it out and check if there is any dust or dirt on the connector
Dec 02, 2012 | Computers & Internet
This Acer ASPIRE AS5551 4200 keeps freezing up like every few minutes. It's fustrating to have to wait for it to come active again. So I just stare at this lap top until it availabe to work with.
Your laptop is overheating very quickly, try putting a fan to it at all times. For a semi-better solution, get a can of compressed air and blow inside the cooling vents with it to clean out some dust. If you don't trust yourself with this, try sending it to a computer shop to have it professionally cleaned.
Jun 20, 2011 | Acer Aspire AS55514200 Notebook
My lap top is just switching off every once in a while , when i am working on it. pls adv?
it is probably overheating. Use some compressed air to clear out dust in the processor heat sink. Place the nozzle near one of the vents and blow it out.
Apr 28, 2010 | Apple Mac OS X 10.4
When powered on, the power button lights up; so
try using a can of air, or air compressor to blow the dust out of the bottom of the lap top, try restarting it and see if it powers up, fan only comes on right away if there is a big dust build up, this should fix it
Mar 13, 2010 | Gateway M305CRV Notebook
Power
If the fan is spinning quite fast then the overheating problem is most likely dust clogging the fan and heat-sink assembly. Blasting air into the fan and heat-sink can only make it worst as you are forcing the dust further into the heat-sink fins.
Remove the panels covering the vent and fan/heat-sink, loosen the dust and vacuum to remove this dust off the fan and heat-sink. Check the fan to see if it spins freely, if not replace the fan.
After re-assembling and boot up, if you still have heating problems, addition cooling can be employed by purchasing a laptop fan assisted cooling pad. Place the laptop on top of this pad and the fans on the pad will direct additional cooling air to the laptop's vents.
Mar 08, 2010 | Gateway ML6732 Notebook
Lap top keeps rebooting
Sounds like it could be an overheating problem if it happens after a long period of operation. Try downloading a hardware control utility to check the CPU temperature and control fan speed. look here
http://www.howtoarchives.com/2009/12/fan-control-speed-for-laptop
Of course this assumes that you can reboot after the pc is switched off for a time.
Feb 10, 2010 | Toshiba Satellite A10-S129 Notebook
My Lap-top fan is allways on the full speed. Eaven when i've just turned it on. The fan actually causes the Lap-top to overheat. What should I do ??? My computer is Hp G7000.
There clearly is a problem with the air flow for cooling the radiator.
First, make sure you don't put your laptop on any soft surfaces, like your bed for example - soft underlay will press against the bottom of the case, obstructing the air intake grill.
Second, if it still happens on a hard surface (try placing the laptop on two pencils, to elevate it even more), then your air duct and the radiator itself may be clogged with dust and lint. You will need compressed air to blow away the stuff. Turn machine off, and blow into the air outlet grill, located on the side or rear of the case until all dust comes out.
Nov 29, 2009 | Computers & Internet
SHUTS DOWN RANDABLY
What we need to do if determine what temperatures your computer is running at, download and run this software.
http://www.cpuid.com/hwmonitor.php
Please post what the temperatures read after you have had the computer running for a little while. Most likely this issue is a heating issue. Thank you.
Apr 27, 2009 | Averatec 6100 Notebook
Dell Inspiron 1200 Notebook Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
