Question about Microsoft Windows Vista Ultimate Edition
A vista OS is failing to detect lexmark 8300 via USB port When i plug a flash or another usb device on the same port it plays i tried to reinstall the drivers but they cant work. what could be the problem the OS am using is Windows Vista, the printer drivers are for vista too
  • thefenix1983 May 11, 2010
    are your copy of vista and the driver you speak of up to date?
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    What is the exact model number of your printer?
    Is this an X8350?
  • 48 Answers
Ok.....
  • click the start button.
  • type "services.msc" in the run bar.
  • Allow it through UAC.
  • now search for an entry called "print spooler
  • double click it
  • in the startup type type select "automatic".
  • restart system
  • this should fix ur problem.
Posted on Feb 15, 2009
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Drivers for 8300 series to windows vista
You can download the drivers from:
www.lexmark.com just enter your model in the search box.
Aug 22, 2008 | Lexmark Office Equipment & Supplies
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
Hope this helps
Nov 07, 2012 | Computers & Internet
Asus m2n68-am plus motherboard unable to detect lexmark X1270 printer. I recently upgraded and installed Ausu M2N68-AM PLUS motherboard, but when i connect Lexmark X1270 Printer via USB, it is unable to...
Have you tried any other USB devices ? Did you load your motherboard USB drivers
usually the steps for installing a usb printer is to load the drivers, and then you will be prompted to
plug in the printer and turn it on, at that time your system will finish loading the drivers and complete
the setup process..
Feb 19, 2011 | ASUS M2N68AM Plus Motherboard
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Jun 02, 2009 | Lexmark X8350 All-In-One InkJet Printer
Incorrect Port Detected
According to Features and Specs on Lexmarks website, this is a All in One? i.e Fax, Printer, Scan & Copy? also it's a Network type?
If so have you chosen the correct settings via the Printers Dispay and Control Panel? ...... I assume you have and everythinh in Device manager looks good, i.e no Yellow and or Red Icons over anything listed there, especially USB....correct?
If your Vista is the 32 Bit then the driver file should be: cjb5000enOSS.exe (87.7MB)
If Windows Vista x63 then it will be: cjq5000enOSS.exe (132.76MB)
Hope the above helped,
cheers,
Bastian
Jun 02, 2009 | Lexmark X5075 InkJet Printer
Onboard usb
VIA needs to stop making USB chipsets... lol... Are you sure you have USB legacy support enabled? Moreover, the default Windows XP drivers are not error free when used with a VIA Rev 5 USB Host Controller because it's actually a VIA Enhanced Host Controller. Every time I have USB problems with the VIA Enhanced Host Controller I go to there website, download the driver, and it usually fixes the problem.
USB 2.0 (VT6202, VT6212, VT6214/L)
Moreover, I have plugged in a Microsoft Wireless Optical Mouse and Windows XP could not detect it until I installed Microsoft Intellipoint; if you can believe that. Try also installing the mouse drivers as well...
Nov 27, 2008 | MSI 865GM3-LS (MS7043020) Motherboard
On-Board USB Problem
try to download and install a USB driver or came with your motherboards cd it has a usb driver too. hope that helps!
CHARCOIS
Aug 23, 2008 | VIA P4MA Motherboard
Microsoft Windows Vista Ultimate Edition Logo
146 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
