Question about GE DVLR223 Dryers
Well i wanna know the wires of the timer touch a metal cover and did a short cut my question is do i need to change the timer of what else do you think could be the problem a fuse ?
Because it use to work before that happen now it doesnt wanna turn on
  • GE Master
  • 2,247 Answers
You'll have to call in a tech to check it out or replace the dryer,nobody can answer that question without being there and checking the dryer with a meter,if the wires from the timer touched metal and i can't see how that happened unless someone worked on it without unplugging it you could have cooked just about any wire or part that those wires go to but then again you could change the timer and it could work but you have to check it with a meter first,that timer cost around 140 dollars,to much money to just guess at.
Posted on Nov 23, 2013
John deer z225 blows red pto fuse when I try to start it
You are going to have to find where the wires are touching the frame. there is a short somewhere trace the wires and see if you can see where the wire is cut and touching the metal
May 08, 2016 | Garden
Chain saw starts but cuts out as soon as i press trigger
This I just a wild guess but here goes.
Most chain saws have a on off switch located fairly close to the throttle. The switch kills the engine by grounding out the wire attached to it. If the insulation has been rubbed off the wire and the metal linkage for the throttle touches it it will short the wire to ground and kill the motor the same as the switch. Remove the air cleaner cover and check wires for bad spots .tape up any bare spots and relocate wiring away from throttle linkage if necessary .
Hope this helps.
Bobalix
Jan 17, 2015 | Garden
I need help figuring out why the horn honks continuously after changing multi-function swicth on 1995 Chevy 4 wheel drive pickup
YOU MAY HAVE PINCHED THE HORN WIRE, IF IT IS GROUNDED THE HORN WILL STAY ON HOPE THIS HELPS BILL
Jan 07, 2015 | Cars & Trucks
Installed fan and it kept blowing the circuit, so I checked the wiring and on the motor where the switch is that changes the rotation of the fan when I changed the rotation I pushed it in a little and went...
Check for a bare wire touching metal somewhere. Check the wires closely as there might be a cut In one of them and Its touching another wire.
Sep 26, 2013 | Heritage Dryers
Car electrical problem
There more to this than a short in the ABS wires
Aug 18, 2013 | Cars & Trucks
When I connect the 240 volt motor directly to hte GFCI breaker it works fine, however when run throough the time clock, when I turn on the breaker, it trips the breaker
You have T104 timer that controls 240Volt motor.
You have 240Volt GFCI breaker.
GFCI to motor works fine.
GFCI to timer trips breaker.
Either timer is wired wrong, or ground fault in the timer.
Open following links to review wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
1) Make sure clock motor wires are on terminals 1 and 3, and that clock motor is 240Volt WG1573 and not 120V WG1570
2) Try connecting GFCI hot leads to terminals 1 and 3 and don't connect wires to motor.
3) Click manual override both directions and see if a short appears.
4) Remove ground wire from timer but leave power connected. Test metal timer body to ground wire to see if there is power flowing to ground.
5) Unscrew clock motor from body, and make sure clock is not touching metal body, repeat test to ground to see if clock motor is bad.
6) Remove small white wires that power the clock, to test if clock is shorting. Replace WG1573 if clock is bad.
7) Connect 240Volt motor to terminals 2 and 4. Click override back and forth. Then reverse wires to 4 and 2.
Jun 24, 2011 | Intermatic T104 24h 208-277v Mechanical...
Dualit Toaster trips RCD on consumer unit as soon as the timer switch is turned
One of elements, or one of the wires have be cut and is touching the metallic body so you need to replace the element or wire
Mar 09, 2011 | Dualit 20084 2Slice Toaster
Dryer timer works but start button doesn't and wont turn on
I would check the door switch. If it's bad, the dryer will not run. You can check it by taking the two wires going to it and tying them together. Be sure to tape them together so they will not touch metal and short. If the dryer runs, replace switch. If not you most likely have a bad thermal fuse and or thermal cut off.
Oct 12, 2009 | Kenmore Dryers
Hoover 1200 front loader washing machine is tripping mains ecb
you have a direct short circuit unplug the machine and remove the plug cable cover then: look for wires touching or, wires touching the metal of the machine the plug wires should only touch their respective screws if these are alright then take a multimeter set it for resistance (ohms) place one probe on a plug pin and the other probe on one of the other plug pins if you see continuity you have a short check all interior wires until you find a blackened burned wire etc. when you have high continuity you have fixed the problem
Apr 26, 2009 | Washing Machines
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
GE DVLR223 Dryers Logo
43 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
