Question about Cisco 678 Router
CAN I USE A CISCO 678 WITH DSLEXTREME AND IS IT A ROUTER OR MODEM
SEE ABOVE FOR MY QUESTION.
    Scholar:
  • 108 Answers
Https://www.dslextreme.com/Support/KB/Article.aspx?questionid=10354
List of modems for use with DSL Extreme.
Posted on Jan 15, 2009
Verizon dsl and cisco valet
Connect your computer directly to the Internet modem and make sure that you have Internet access directly from the modem.
If that is working properly then connect the modem to the Internet port on the router. Connect the computer to port 1 on the router.
Reset the router and configure it manually.
Here is link which will help you troubleshoot Cisco Valet M10 or M20 router
Mar 01, 2014 | Linksys by Cisco Cisco Valet Plus Wireless...
Connecting Cisco 851 cable to virgin media super hub Problem
are you using the cable modem as your router? if so then simply hard code your media hub to a static ip address in the same range that the router/modem communicates on. (private address side)
Dec 27, 2013 | Computers & Internet
Problem cisco EA6500 to i-cable router HK
Power off Cable Modem, PC, router, and then disconnected them. Directly connected Cable Modem with PC (Don't connect the router) and power on Cable Modem. When Cable Modem is ready with LED lamps under normal status, also power on PC and try to access Internet service. If Internet service is resumed, please study the router setting of Cable Modem which referred to router's user manual.
Apr 21, 2013 | Cisco Linksys EA6500 Smart Wi-Fi Dual-Band...
How do I connect cable modem to cisco 3560 switch and configure it?
The cable modem will need to go through a router because it needs a NAT and PAT translation table, connecting the cable modem direct would lose the ability to get to the internet.
Jun 05, 2012 | Cisco Catalyst Compact 3560-C PD PSE -...
Using WRTS4GS2 Cisco Router and could not access the internet. Remobed router and had instant access to the internet.
Contact your ISP. Some ISPs limit the number of computers that can simultaneously connect to your cable-modem. If you change computers, you have to tell your ISP.
Or, power-off your cable-modem, to "reset" it.
Connect the Cisco Router to the cable-modem.
Power-on your cable-modem.
Power-on your router.
Connect your computer to your router, and see if you get Internet access.
Dec 20, 2010 | Computers & Internet
I wasnt able to connect using my modem, then this appears error 679. What does 679 error means?
Error 678 and Error 679 Connection Errors
Error 678 The remote computer did not respond (No dial tone)
Error 679 The Specified destination is not reachable
Both errors are very closely related as they both suffer from the same causes
Causes
ISP (internet service provider) problem.
You have a phone line problem.
Router / Modem is disabled, this can be due to.
The LAN or Phone cable is disconnected.
Your firewall is blocking the connection.
The Winsock file needs to be repaired.
A phone line does not have a line filter installed.
The modem drivers are corrupt.
Spyware.
Your modem is faulty.
Your username, password is wrong.
Incorrect ISP or Router / Modem Configuration
Hope it helps.
Oct 09, 2010 | Computers & Internet
Can't connect cisco router
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 23, 2010 | Linksys Wireless-G WRT54GS Router...
Cisco 1721 router serial port not showing any loop.
the problem is with your modem....did you tested the local loop from router to modem....are u getting local loop from one modem till router or not...try first checking local loop from modem to router...
Nov 15, 2008 | Cisco 2610XM Router
Point to Point T1 Using Cisco 2800 Routers?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Dec 03, 2007 | Cisco (WS-X3011) Router
Cisco 678 Router Logo
162 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
