Question about Fujitsu LifeBook AH530 NoteBook
My ah530 wont boot up
Windows has crashed and my laptop wont bootup
  • 2 more comments
  • woo robins Dec 10, 2012
    it still wont boot, it list a load of stuff and then stops and shuts down
  • Brian Sullivan
    Brian Sullivan Dec 11, 2012
    If your laptop won't turn on, you could have any number of problems. The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter. Conversely, it may only appear to be a power failure, and the problem may lie with another component. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. check ram modules even remove check fot dust and debri then reseat them
  • woo robins Dec 11, 2012
    brian thankyou so much for your help, sorry i didnt explain enough, it will boot to the start of windows and then go idel. I will have to take it to a shop.
  • Brian Sullivan
    check the ram
  • Fujitsu Master
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials
once you have your computer running or you could do this in safe mode Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. Scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might still have a virus If you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections Click start control panel administrative tools computer management disk management right Click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules You should always ask for a guarantee on compatability before purchasing any ram and buy working pairs if possible. you might have to many programs running at the same time putting to much strain on the CPU Try uninstalling a few unnecessary programs. this should speed up your computer or you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope it helps.
Posted on Dec 10, 2012
I have a Asus G73JH Windows 7 64 bit operating system. Frequently it crashes into the blue screen of death and subsequently when i try to restart it. I get the select proper boot option error. Upon fu
press F8 on bootup and select SAFE MODE. try to login and do normal things. if this works then this is probably just a driver or application issue. if SAFE MODE doesn't work, this is probably a hardware issue.
Start your computer in safe mode Microsoft Windows Help
Mar 27, 2014 | ASUS Computers & Internet
Fatal error on bootup
I think you can boot your laptop from a bootable disk so that you can fix the issue through another system. You can try Windows Boot Genius to create a bootable disk.
source: http://www.windowspasswordsrecovery.com/fix-windows/windows-wont-start.html"
Jan 07, 2013 | Computers & Internet
My laptop has come up with a blue error screen and will not let me in. The screen says "A problem has been detected and windows has been shut down to prevent damage to your computer.... Technical...
Don't give up try booting into SAFE MODE press F8 at bootup and choose safe mode, with networking. Then at least you can troubleshoot what is wrong, it is often a bad Video driver. It may require reinstalling or updating, or some other driver that is giving you this BSOD.
Feb 01, 2010 | Computers & Internet
Will not boot
It can have boot virus and when booting it finds your antivirus soft and if cant stop antivirus then calls "crash" screens, also sometimes real crashes heppened vith driver incompatible or incorrect parameter stored. If you have any LIVE Windows CD or linux boot from it anc check for viruses, also make disk check with disk utility. If not corrected windows must be reinstalled. If you havent try try "last good known configuration " from bootup screen, to call boot press F8.
Aug 03, 2009 | Toshiba Satellite 1805-S204 Notebook
My dell laptop wont do disk check and wont continue on windows what will i do to fix it
You should try to boot it into safe mode and then run a virus scanner you should also be able to run disk check in safe mode. Usually pressing the F12 key during bootup will bring you to the boot menu. You have to watch carefully because the option appears really fast at the beginning of bootup.
Mar 27, 2009 | Dell Latitude C600 Pentium III 750MHz,...
Hi grade laptop boot problem
crashing a few times in order to boot can be caused by corrupted boot files that Windows required.
Try do a "scan for bad sectors" checkdisk (Right click C: in My Computer, click Properties. Click Tools tab and then Check Now button, tick both option boxes and it should ask to reboot for the bad sector check. 8c484d1.jpg
You can also use HDD Regenerator to fix corrupted files. Read my other posts for details.
Mar 19, 2009 | Computers & Internet
Bootup problems
AS you boot up, try tapping the F8 key until you get a window giving you the option of multiple types of boots. Use the safe mode boot.
Then do a system roll back found in your system tools.
Mastersage..................................
Feb 19, 2009 | ASUS VX2S-AK039G T7500/2.2/200/2G/15/VBU ...
Gateway 675 fan problem
Check the BIOS in the laptop. The CPU fan and unit fan is controlled by temp. U can set it for a lower temp. The Bios is accessed when U boot up... F2 usually, There should be a 5 to 15 second screen telling u what to press to get there.
Good luck
Mar 07, 2008 | Computers & Internet
Fujitsu LifeBook AH530 NoteBook Logo
780 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
