Question about Philips GoGear SA5285/37 Digital Media Player
Hi i'm using philip gogear audio player.suddenly frm last 1week it stop working properly means i can't able to see the display properly (starting prob) then i taught may be virus effect so i reset the same. now porb increase now i cant able to on my IPOD. i connect the same with pc to on but in that showing installing after 80% it got hanged. i tried 2-3 time Pls help me
  • 8,596 Answers
Run a Repair in the most recent version of the Philips Device Manager from Philips website
Posted on Mar 07, 2009
What does file not supported mean on my gogear vibe and how do i change it
Your Philips GoGear Vibe supports these formats:
audio
  • MP3
  • PCM
  • ADPC
  • Audibl
  • WMA
video
  • SMV
audiobook format 4.
More support info:
Philips GoGear MP3 video player SA1VBE08K ViBE 8GB
Dec 16, 2013 | Philips GoGear ViBE SA1VBE08K MP3 Player
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
My model is Philip SA1MXX02W/97 GoGear Mix 2 GBMP3 Player.When I on it, it shows updating 20 percent, then updating 40 percent ; hang there for few seconds and suddenly off by itself. Pls help.
It shows there is some problem with the inbuilt device firmware.The only solution is to do a reset on your device.Please follow the instructions below to reset your Philips SA1MXX02W/97.
1.Insert a pen tip or other object into the reset hole located at the bottom of the GoGear Mix. Hold until the player shuts down.
If the reset option is unsuccessful, follow the steps below to recover the GoGear Mix with the Philips Device Manager:
1.On your computer, select Start >Programs > Philips Digital Audio Player > GoGear Mix Device Manager > Philips Device Manager to launch the Philips Device Manager.
2.Turn off the GoGear Mix before you continue.
3.Press and hold the volume button + while you connect the GoGear Mix to your computer.
4.Keep holding the key until the Philips Device Manager acknowledges the GoGear Mix and enters the recovery mode.
5.On the computer, click the Repair button and follow the instructions of the Philips Device Manager to complete the recovery process.
6.When the recovery is completed, disconnect the GoGear Mix from your computer.
7.Restart the GoGear Mix.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 26, 2011 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
Philils go gear mp3 player
My Philips go gear is not working.how to repair
Jan 21, 2009 | Philips GoGear HDD6330 MP3 Player
Sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Sep 03, 2008 | Philips GoGear SA178 MP3 Player
Wont come back on!
What OS are you using?
I know that it is not fully compatible in Vista.
1) Try using an XP machine and plug it in there, in any case, reformat the MP3 player using FAT.
2) Try uninstalling all software for your MP3 player from your PC and reinstalling it.
3) Here is something else you might want to try:
Try doing a soft reset.
  1. Press and hold the Power On/Off key and the Volume + key for a couple of seconds.
  2. Then switch on the GoGear using the Power On/Off key.
This is soft reset, your songs will not be lost.
4) If all else fails, it's time for a factory reset:
  1. Connect the GoGear to the AC adapter and to your computer.
  2. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device. Launch the Device Manager at Start->Programs->Philips Device Manager->Philips Device Manager on your PC.
  3. Select the REPAIR tab on the dialogue box and then click "Repair" to start repairing.
    IMPORTANT: All music & content of your micro jukebox will be erased once the repair function completes. 051028091949_1746.gif 051028091949_1747.gif
  4. When repair is complete a dialogue box will pop up; click "OK" and unplug the GoGear from the computer. 051028091949_1748.gif
  5. Follow all the on-screen instructions to complete the repair.
  6. The Device Manager will close automatically once the success message is displayed. Close all opened applications and then unplug your GoGear.
  7. Once the GoGear is disconnected from the computer, the display will show “Firmware Upgrading” for a couple of seconds and then start up as usual.
Hope That Helps!
Dec 12, 2007 | Philips GoGear HDD6330 MP3 Player
Philips HDD 1630 won't charge
I have the same problem I think that the internal battery died... is it possible to change it?
May 22, 2007 | Philips HDD1630 MP3 Player
Philips GoGear SA5285/37  Digital Media Player Logo
118 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
