Question about Bolens 25cc 2-Cycle Gas Cultivator BL425
My bolens 25cc cultivator bl425 will not start it dosnt even fire . Its getting air fuel and spark. I bought it used but it has only been run a few minutes????
How do I replace starter rope?
its not hard to do just be careful as the spring will be under a bind. watch some videos on you tube and you can do this.
Apr 20, 2016 | Bolens 25cc 2-Cycle Gas Cultivator BL425
Bolens cultivator model BL425 engine will not start
I would make sure that you have the proper gas/oil ratio mixed first. If that is ok then I would have the filter changed. If that doesn't solve the problem then you should take it in to have the carburetor serviced.
Jul 04, 2014 | Bolens 25cc 2-Cycle Gas Cultivator BL425
Bolens cultivator model BL410 won't keep running
clean the screen inside the muffler
Aug 03, 2012 | Garden
What else could cause my troybilt cultivator to not run?
spay starting fluid in the air filter if it fires then you have a carb/fuel problem (keep in mind small engines need fuel 30 days or newer )if no fire on starting fluid check for spark if you have spark good fresh fuel remove the muffler and try it again if it runs with the muffler off then open the muffler and clean the screen iside
Jun 06, 2012 | Troy-Bilt Garden
I HAVE TRIED ALL THE IDEAS REMOVE SPARK PLUG,INSERT SMALL AMOUNT OF GAS ETC. IT HAS GAS AND FIRE BUT NO START
if you say it has fire,then the small amount of gas you poured into the spark plug hole will fire if theres a spark,if it does fire when this is done its your carb thats fouled up,remove the air cleaner from the carb and when it fires,take WD-40 and spray it into the carb where you removed the air filter&cover and see if you can keep it running,also did you remove the sediment bowl off the bottom of the carb to see if and how much water/dirt is present in this bowl???
Mar 22, 2011 | Honda 25cc 4-cycle Mini Tiller
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I have a Bolens BL410 cultivator that stops running when it gets hot. The engine starts perfectly every time, but after using is for a couple of minutes the motor speeds ups suddenly and then shuts off. I...
Hi and welcome to Fixya. The symptoms your describing are typical of what happens when the engine experiences fuel starvation.
It can be caused by a clogged fuel filter screen located at inside the attachment point of the fuel line manifold on the carb. Turn off the fuel and remove the mounting bolt for the fuel mainfold. Very carefully remove the plastic screen inside the manifold and clean off the debris that has built up on the screen.
If the screen was visibly clogged you probably have solved your problem. Just make sure you re-install the screen when re-connecting the fuel line manifold.
If the screen was not clogged then check your fuel lines for cracks. Air being introduced into the system will cause the same symptoms you describe.
If the problem persists then there is the possiblility that the needle and seat are partially blocked inside the carb itself on the bottom of the carb body after you remove the bowl. (Usually not the problem) However the bolt that holds the bowl on has 1 or 2 holes in it that can also clog and they must be clear.
And finally there is a BRASS jet that unscrews with a screwdriver in the bottom of the long draft tube (way below the throttle slider / needle) that gets clogged. Unscrew the brass jet and force air from the threaded end to clear the orifice.
By this time you probably figured out the float comes off with the bowl. note which side is UP! Also DO NOT adjust the float level it is preset. u|Unless you bent the float control arms it does not need adjusting.
Turn on the fuel... and start the unit after re-assy and it should run just fine. You should be tilling real soon!
Jan 29, 2010 | Ryobi Cultivator
Bolens 2 cycle tiller will not start
Improper adjustment is a possible problem. However could also be trash in carburetor. Adjustments can be tricky. Recommend a tech.
May 18, 2009 | Garden
I have a bolens rear tine tiller that will not run. The carborator has been completely cleaned, new gas, new spark plug, new oil, and new gaskets. It seems like it is not getting gas from the tank. Will...
is the fuel filter clogged? you may need to check the engine compression for bad valves or rings.if the compresion is off it wont get gas . check the fuel filter first though and keep me posted.
Apr 23, 2009 | Mtd Products Yard Machines 158CC Tiller
Bolens 25cc 2-Cycle Gas Cultivator BL425 Logo
146 people viewed this question
Top Bolens Garden Experts
cwradio73
ray gallant
Van Phelps
Are you a Bolens Garden Expert? Answer questions, earn points and help others
