Question about Acer Aspire 3610 Notebook
I cant get spanish switched to english onacer aspire 3610
I have tried every thing I could think of to switch spanish to english I went into the chose a laguage section it only had english canada I tried that it still would not change I hope you can help thank you
  • Rick Van Bibber Dec 12, 2012
    what I did Before I recieved your solution Irecieved a recovery disk for 3610 that let me choose english I never got to try your solution Im sure Ill be asking for more help Im just now learning how to use a computer Thanks for the help
  • Acer Master
  • 2,878 Answers
Windows 7 only!
You need to install language packs form Windows Update.
If already installed? To change in Windows, go to Start > Search and type Change display language. Choose from list.
Posted on Dec 10, 2012
pagebor
  • 2785 Answers
SOURCE: Acer aspire 3610 not booting pass flash screen and if it does gives an error openning windows
try by changing the data cable and check the jumper setting of the hard drive
Posted on May 12, 2008
  • 244 Answers
SOURCE: Boot problems with Acer Aspire 3610
do you have power ? if no, check your power outlet and ac adapter first, if both of them are ok, it could be your motherboard.
if you have power but no display, this is called no post.
reseat your memory. if still not working, use 1 memory and try to put it in different ram slot. and if this is still not working, your motherboard is bad
Posted on Jul 26, 2008
  • 244 Answers
SOURCE: USB Driver is not installed with aspire 3610
you can download from www.acerpanam.com
if you can't find it under Aspire 3610, try under AS5610/AS5630/AS5680
good luck
Posted on Aug 01, 2008
jose_v17
  • 227 Answers
SOURCE: Broken screen on Acer aspire 3610
I don't see a problem with the screens it seems that they both have the same specs. The casing is where you might have an issue just check to see if all the clips and screws are in the same positions. you never know till you try
Posted on Mar 25, 2009
  • 123 Answers
SOURCE: chose french windows instead english windows by accident and need to change it
Open Regional and Language Options by clicking the Start button, clicking Control Panel, clicking Clock, Language, and Region and then clicking Regional and Language Options.
Click the Keyboards and Languages tab.
Under Display language, choose a language from the list, and then click OK.
Obviously you'll have to work out the French equivalents of the options but should be fairly obvious
Posted on Apr 19, 2009
Spanish to english
without phone model - I can give you vague solution but here goes
find apps. in spanish it will be most likely be aplicaciones
find settings could be Ajustes in Spanish
system - Sistema in Spanish
look for Idioma e introduccion in Spanish
then look for idioma in Spanish
change from Espanol to english
Aug 15, 2016 | Cell Phones
Why cant I text in english on my zte android phone
Please try using these steps to change the language in the device. In standby Mode---Menu key ---settings---languge & keyboard---select language---switch language.
Jan 26, 2013 | ZTE Score
Phone language went to spanish want to switch back to english
This is what to do.
Go to > Menu
Go to > Prog/Herram
Go to > Programacion de Telefono
Go to > Idioma
Go to >Spanish to English
Regards
Jun 30, 2011 | LG RUMOR Cellular Phone
My computer had some loging in problems and when i took it to get fixed they changed the language from English to Spanish (where i live they speak spanish). I want it to go back to English but i cant...
You do the below seteps: This is what you do:
Start > Control Panel > Clock, Language, and Region > Regional and Language Options.
Once in the Regional and Language Options, click the Keyboards and Languages tab. If you see a drop down list of languages, see if it is set to English. If not, set to English. However, if you do not have this list there, you may need to install it.
May 21, 2011 | ASUS Eee 4G Notebook
Its all in spanish and i what it in english
try going to the panel control and clicking on language and swith it to english but if u r having trouble understanging reading spanish then find a translator online and look up the words u cant understand
Sep 21, 2009 | Acer Aspire 3680 Notebook
32" TV MENU IS IN A DIFFERENT LANGAUGE NEED TO CHANG IT BACK TO ENGLISH HELP????
Try typing the words you see in the meny into a spanish translator to find the correct menu to switch.
I think you should be able to see the word language when in spanish mode.
Jan 14, 2009 | Curtis CM32020S 32" TV
Cant test webcam for fotos or video - can only use for video chat
well i believe you can reformat your computer to be in english. Unfourtunatley, you have reimage your computer in order to do that and it would reuire you to backup your data unless you dont care if your entire hardrive is wipped. For your webcam problem, you have to go to the control panel and then go to the webcam options and allow the input device to appear on the screen.
PLEASE RATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jan 02, 2009 | Acer Aspire 3610 Notebook
How do i switch my phone from spanish to english.
Go to settings and tools....select 1settings....select 1 display....select 4 Language...then select english
Hope this helped...later
Dec 20, 2008 | Kyocera Xcursion KX160 Cellular Phone
Language
Oh boy that's a real problem. I guess the menu is there but you don't understand it because it's in Spanish.
I don't know this particular phone but thinking logically, there are four things I would consider.
1) Find someone who can speak Spanish, there are lot of people who can.
2) Find someone who has the same phone that is in English and copy the key presses.
3) Use Google language tools to help you interpret the Spanish menu
4) Take you phone to a dealer
Hope this helps....
Feb 13, 2008 | Nextel i530
Changing from Spanish to English
In APPS, there is no option for English. You need to select another language (DANSK usually comes first), then select option 2 for English (option 1 will be the language you chose in APPS).
Sep 17, 2007 | Texas Instruments TI-84 Plus Silver...
Acer Aspire 3610 Notebook Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
