Panasonic th-42px600b flashes 10 times then 3 seconds later does it again
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Its a error code and usually the power supply or something directly connected to it. Was there a small pop when it failed?
Posted on Dec 10, 2012
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Posted on Nov 25, 2008
  • 20 Answers
SOURCE: my panasonic th-50pz800u won't power
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Posted on Jan 04, 2009
SOURCE: my panasonic plasma TH-42700U it turned off while
solution of light blinking
Posted on Jul 11, 2009
  • 8457 Answers
SOURCE: i have a plasma panasonic viera TH-42PV60A stand
Not power supply,it the backlight video board it dead.
Posted on Nov 23, 2009
Testimonial: "cool thanks alot"
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
Hi Friends! I have a Panasonic TH-L32C20R. When
Something worth trying that worked for me and costs nothing is; remove all leads except the power lead. Hold the on/off button on the TV in until the light stops flashing, release button and and press again. If it fires up your good to go if not your nearly finished disconnecting everything ready to send off for repair! Good luck, BTW the number of flashes indicate a fault code that you can look up online.
Sep 22, 2013 | Panasonic TH-42PX60U Television
I have a Panasonic model TH-50PZ80U and the red light for the power flashes 10 times. I unplugged for 20 minutes and plugged back in to find it flashing 10 times again
I can tell you what is the caused of the 10 flashes of the led light (Panasonic Plasma TV TH-50PZ80U). I'm online at pay question click it here if you want to know it and I will help you to fix it yourself.
Sep 27, 2011 | Televison & Video
Dead, power light flashes 10 times then nothing for 4 seconds then flashes 10 times then repeat. This is after I inserted an SD stick.
Unplug,replug the tv about hour later.Tv will,reset itself,back to factory setting.Should have power now.Still have the same problems.The power supply board is dead.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 07, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera TH-42PX600B, menu and channel info
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 10, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
May 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
