Question about Whirlpool Duet GHW9150P Front Load Washer
Not workthe starter bottom does - Whirlpool Duet GHW9150P Front Load Washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
See other post
Posted on Dec 10, 2012
Remove a starter
  • Remove the negative and positive lead on the battery.
  • Locate the starter under the vehicle. The starter will be located to the right of the motor on the bottom. Access the bolts comfortably from underneath the truck.
  • Remove the bottom bolt with a socket wrench. The ground cable will be attached. Save the bolt for reinstalling the starter.
  • Unbolt the positive cable on top of the starter. Use a socket wrench to remove the bolt.
  • Unbolt the top of the starter with a socket wrench. The starter will be loose.
  • Pull the starter straight out. Use both hands to pull out and forward as the starter is heavy. Pull forward and lower to the ground.
Installing the Starter
  • Position the new starter in place. Match up the starter to the designated bolt holes on the mounts.
  • Start the top bolt. Turn the bolt clockwise but do not tighten the starter down.
  • Start the bottom bolt. Ensure the negative cable is run through the bolt before starting. Do not tighten the bolt.
  • Tighten the top bolt with the socket wrench. Tighten it snug. Repeat the same for the bottom bolt. Ensure both bolts are tight.
  • Tighten the positive cable to the starter. Ensure the cable is snug to the fitting.
  • Connect the terminals to the battery. Ensure the vehicle cranks. The starter will engage without hesitation if done correctly.
Read more : http://www.ehow.com/how_5707471_replace-starter-ford-ranger.html
Dec 05, 2015 | 2006 Ford Ranger 4.0
Doesn't respond to IR commands
Hi mamcdowall, the remote has lost function to workthe functions of the receiver so what we need to do is reprogram the DISHremote. There will be a few simple steps to get this done so you will need tofirst is press the System Info button on the receiver and it will take you tothe System Info screen. Then you will need to push and release the SAT buttonon the remote, and then you will need to push and release the Record button andyou will notice the number at the bottom of the screen change. I will also sendthe link to fallow from our site.http://www.dishnetwork.com/SupportSection/remote-setup.
I do hope this has helped you out.
Mike Houston of DISH Network Executive Office
Jan 16, 2011 | DISH Network ViP 612
On a 323is model starter replacement. is this difficult?
Disconnect the mattery negative. Remove dipstick guide tube.Disconnect starter wiring. Romove the top and bottom starter bolts. Bottom bolt removes from under the car. Pull and twist the starter till the solenoid is at the top and remove the starter. Some models have a bracket at the rear of the starter that also needs to be removed before the starter can be removed.
Oct 14, 2010 | 1997 BMW 318
Fax thru Internet help
Magic Jack is lying to you. ALL fax machines are Analog devices, Magic Jack is Digital
Jun 21, 2010 | Muratec M1250 Fax
Hi, my 1qaz caps delete and enter keys broke
try running a linux live cd and if it works with that then it's not the keyboard. possible cause is something has been spilled on it. hope this helps
Mar 26, 2010 | Compaq Presario 700 470024-192 Notebook
Driver not compatible with windows 7
Becasue of the age of the camera as compared to the newness of Window 7 it won't be. I don't expect pentax will go back that far in updating, but I would check their web site because firmware updates are are usually workth installing. http://www.pentaximaging.com/support/manuals-and-literature/
Your solution is to but a wid 7 compatible card reader and use the card reader to download your picture files to the computer. You will likely need new software for editing and sorting since the old pentax software is not likely to be win7 compatible.
Jan 01, 2010 | Pentax Optio S5i Digital Camera
2000 jetta automatic problems
there is a relay for the transmisson under the dash that controls the shifter, found out alittle about relays, there are some cheap ones on the net!
Feb 26, 2009 | 2000 Volkswagen Jetta TDI
Power to Protron TV
I had a power supply for my Protron 32 inch TV that was not working. I bought the one on ebay and it stopped working after only three weeks. Ultimately I found a guy who could fix my original power supply for a reasonable price. It's been working for a year now with no problems. I wish I would have tried him first!!!! If anyone is interested his email is dave@thola.com.
Mar 26, 2008 | Protron PLTV-32 Television
Whirlpool Duet GHW9150P Front Load Washer Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
