Question about Home
Newly installed Galaxy Aqua 3000 not working - told water is low pressure!
We have a new Galaxy Aqua 3000 (9.5kw 026415g) installed and its not working. engineer says not enough water pressure (london). the last electric shower worked fine. can this be true and what can we do to fix or test this?
  • 374 Answers
SOURCE: Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Posted on Oct 21, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Posted on Dec 15, 2008
  • 102 Answers
SOURCE: low water flow in Shower
Definitely try reversing the cartridge.
Posted on Mar 11, 2009
Bati99
  • 88 Answers
SOURCE: Water not hot enough coming from my power shower
The Redring Superflow 3000 was not produced after 2001. You can try calling the showerdoc 0131-538-4343 or going to showerdoc.co.uk
Posted on Apr 17, 2009
  • 297 Answers
SOURCE: 1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Posted on Jul 27, 2009
Shower head keeps dripping water does not stop when turned off
I would look into possible failure of the solenoid valve assembly or the valve top assembly, which are parts 8 and 7 respectively, on the linked page. This site also has all the spare parts for sale.
You are viewing shower spares for Galaxy Aqua 2000 Aqua 2000
Aug 16, 2014 | Galaxy Aqua 2000
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
No water coming out of spout even though water enters system up to and beyond distribution valve.
this may sound stupid but i resently installed one and if then water pressure was not balanced between the hot and cold the unit would not work
Oct 30, 2011 | Aqua Brass Single lever faucet AQUA BRASS...
Bought a aqua option toilet dual flush from American Standard the tube that usually goes into the overflow tube now rides on a float which rises with the level of water as it gets closer to the overflow...
i have the same issue with my aqua option toilet. if you have a water shut off installed on the supply line to the toilet, just close it enough to reduce the supply pressure. no more splashing.
Nov 17, 2010 | American Standard Home
I have low water pressure throughout the house. I
Depends on style of your pressure tank. Some allow you to adjust the discharge pressure.
Jun 29, 2010 | Plumbing
Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Aug 31, 2009 | Plumbing
Newly installed integrated dishwasher will not start
have you checked that the water inlet pipe is not kinked or that it is turned on. some models have water pressure sensors and wont work on low pressure supplys
Apr 26, 2009 | Smeg Dishwashers
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Home Logo
91 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
