My printer says it's offline
  • 7,627 Answers
Reboot you computer. Check connection to your computer. Is it wired or wireless? Reboot the printer, unplug and plug in.
Posted on Dec 11, 2012
2 Suggested Answers
  • 81 Answers
SOURCE: Hp printer'offline" & will not[rint.
Make sure the printer is plugged in and turned on. Also check the USB cord; is it plugged in all the way on both ends? Also check the quality of the USB cord to make sure there are no snags.
Posted on Jun 22, 2011
MX340 connected to mac is offline despite drivers, cable and wifi assistant update. I have set this up before with the cd sent information to print. I see the printer in my printer queue but it says...
Try plugging it in directly.
Sometimes the wifi printer has to be set up AFTER the hardwire setup.
If you are desparate, plug it in directly to your computer to get your job done and figure out the wifi later.
Feb 11, 2013 | Office Equipment & Supplies
The offline icon is blue protected from me. I need to switch to online for printer. What is my next step.
Un install the drivers & re install again to over come from the issue...If system not recognising the printer then check with another USB cable...
Feb 02, 2012 | HP Photosmart 2710 All-In-One InkJet...
Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
Nov 22, 2011 | Canon PIXMA MP495 InkJet Printer
A couple times a week my HP Deskjet DI660 printer goes 'offline'. When this happens a message appears 'new hardware found'. And my printer will not work until I have disconnected the the...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 26, 2011 | Office Equipment & Supplies
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
Jun 22, 2011 | HP Office Equipment & Supplies
Hp deskje d2360 printer showing offline error
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
My HP Deskjet D1341 printer won't print. Says it is offline. I go in and right-click to put it on-line, but it still won't print,,,goes back off-line. I posed this problem last Thursday and paid $$ to...
Goto the below mentioned link and select your operating system now click on the next button.
Expand the Utility - Diagnostic Utility and download the print diagnostic utility and this will show you what the problem is with the printer or with the computer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=1839855#N672
Oct 05, 2010 | HP Deskjet Printer
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
jasbo
jasbo
