Question about Frigidaire Freezers
Upright freezer leaking blue fluid from underneath unit
5 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Posted on Sep 27, 2008
woodchuck789
  • 4059 Answers
SOURCE: Is a Kenmore Elite Upright Frost-Free Freezer
Is the drain pan underneath overflowing? If so the water filter may be clogged and the water leaking past it to the pan. The normal amount of water from the defrost cycle shouldn't fill it up. The condenser fan usually evaporates the water by blowing the warm air on the pan.
There could be a leak because or the defrost drain being stopped up but this usually comes out the bottom of the freezer door.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 16, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Frigidate upright frost free freezer and
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 29, 2010
  • 30 Answers
SOURCE: Our upright freezer is leaking
Many maybes here. Leaking water usually indicates a problem with defrost. You need to remove either the rear wall or the bottom cover inside the freezer. Most will have screws, but some will be a friction-fit. Bottom line is to look for ice, either on the rear wall or the bottom.... wherever the ice is showing. This is where you will expose the evaporator (cold radiator) and drain fitting.
Odds are that your drain is plugged and causing the evaporator to ice-over. Expose this area and look for anything (I've seen peas, price labels, corn and multiple items causing the issue) that is plugging the drain fitting. You may need to turn the unit off for a day to melt the ice in this area. If you do, remove ALL product and place towels at the bottom of the unit to absorb the water that will accumulate. Not doing the towels could damage your floor.
When the drain fitting is exposed, if there is something obstructing the opening, remove it and ensure that the line if not plugged by pouring a small amount of hot water into it. That water should end up in the catch pan below the unit.
If there is nothing plugging it, make sure that the fan is operational. If not, replace it. If fan is good, my advice is to replace the defrost heater, defrost safety control and defrost timer... all of them.
Good luck. If I had a unit as old as yours, I'd not call a tech. I'd replace the unit.
Posted on Jun 19, 2011
My 20 cubic foot fridge dairy upright freezer has started leaking small puddles of water underneath it is only 3 months old
Contact shop, less than a year old they are responsible for repairs / replacement. Have you read instructions to make sure that you have done all that you should regarding any draining of system thet is required.
Feb 22, 2016 | Freezers
Blue liquid drains from bottom of freezer
you have refrigerant on the floor you need to A&E FACTORY SERVICE @ 1-800-862-9226.
now you can not do it yourself you need a trained technicians to do the work
Jan 16, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
It's leaking water from underneath the unit
Hi there, I know that most units have a drip tray at the back or under the unit itself. well the older ones anyway, not sure with really new ones, but they shoukd. these trays hod water condensation and any drainage from the fridge itself. These trays sometimes have a coil in them which heats and help to evaporate the waterso that it does not overfill and spill out. these trays can become overfilled, the heating elemet can stopworking or
Jun 01, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer seems to be leaking freon. repair person told me that if there is a leak then it is up in the walls of the freezer and cannot be repaired. Is this true?
Yes, if the condenser coils are not on the back of the freezer or underneath they put them in the walls of the freezer where they are not accessable with out destroying the box to get to them. So if that is where the leak is then no it is not repairable.......if the leak is in the evaporator and if the evaporator is Alumium then it is also not repairable.
Apr 17, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
Ice keeps forming on the bottom of the freezer - like a leak on the back side flows into the bottom toward the door.
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Is a Kenmore Elite Upright Frost-Free Freezer supposed to have water leaking from underneath it? Would this be the water accumulating from the "defrost cycle" on it?
Sep 16, 2009 | Freezers
Problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Feb 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire freezer, only 2 bottom slelfs freeze
If your freezer is six years old the compressor warranty is also over. Sounds as though the system has lost its refrigerant charge. A refrigerant leak in these smaller units is difficult to locate and somewhat expensive to repair. Your choice.
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
197 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
