Question about Dell Inspiron 1501 Laptop
Media test failure, no os
Was trying everything i could find on the net and then the other day i plugged a external Que drive into it and it booted up fine. so i went to a restore point, backed it up to see if i could fix the problem and then it went right back to media failure no os. if my hard drive is bad why would it boot the one time?
  • Dell Master
  • 2,878 Answers
Your hard drive is missing from the system. Or, just does not recognize it.
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Posted on Dec 10, 2012
  • 92 Answers
SOURCE: reseat the hard drive
Hi, You can try this out to reseat the Hard Drive
First safety Steps:
  1. Ensure that the work surface is flat and clean to prevent the computer cover from being scratched.
  2. Click Start before7.jpg , click the arrow before8.jpg icon, and then click Shut Down to turn off your computer.
  3. Disconnect your computer and all attached devices from their electrical outlets
  4. Disconnect any telephone or network cables from the computer.
  5. Remove any installed cards from the ExpressCard slot and the 8-in-1 memory card reader
  6. Turn the computer over.
  7. Slide the battery release latch until they click into place.
  8. Slide the battery out of the battery bay.
  9. Turn the computer top-side up, open the display, and press the power button to ground the system board.
    battery
1. Turn the computer over and remove the two hard drive screws.
screws (2)
hard drive
2. Slide the hard drive out of the computer.
3. Slide the hard drive into the hard drive bay until the drive is fully seated.
4. Replace the two screws to secure the hard drive Then again you can try
Posted on Feb 03, 2009
Nowuser
  • 56 Answers
SOURCE: Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Posted on Jan 03, 2008
SOURCE: No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Posted on Sep 25, 2008
efs_perpends
  • 1996 Answers
SOURCE: Can my hard drive be salvaged?
You can definitely get another one, as long as it's compatible with your system...get the original specs from dell, then search online at western digital, tiger direct, etc. etc.Many online sites will have recommendations for your system.
Please consult links here and here
You may want to run chkdsk to see what's up with it...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 04, 2009
  • 16 Answers
SOURCE: Pxe-e61: media test failure, operating system not found
First, take out any CDs/DVDs and try to boot again. If that doesn't work, your hard drive may be defective.
There will be a cover on the bottom of your laptop that holds the hard drive (easy access). You can try removing and reinserting the hard drive and then booting the PC afterward.
If that doesn't work, you will likely have to replace the hard drive, but best advice would be to take it to a computer technician for further analysis.
Posted on Sep 02, 2009
Testimonial: "I knew it migth be the hard drive, but I was hoping it was not. Thank you."
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
Pxe-e61: media test failure, check cable acer extensa 542
Your computer tries to "boot" from several devices:
* floppy disk
* CD/DVD optical device
* disk-drive
* external CD/DVD
* USB memory stick
* PXE ("Pre eXecution Environment)
To use PXE, you need "media" -- a network cable connecting yur computer to a "boot-server". The "media test faiure, check cable" reports that no network-cable exists, or that it does exist WITHOUT being connected to a boot-server.
Probably, your computer failed to boot from a DEAD disk-drive, and then tried floppy/CD/USB before checking PXE.
Replace the disk-drive.
Jul 30, 2012 | Compaq Presario-Notebook 700 Series, 2500...
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
How can i solve the disk boot failure?
For Disk Boot Failure, below are the steps:-
1) First check your HDD. (Go to BIOS > Run the HDD self test).
2) Make sure there should not be any external media connected to your notebook (CD, USB drive etc.)
3) If your HDD is OK, then You need to install the OS again.
WIth regards
FIXYA
Please post your feedback and Vote if the problem resolved as per your satisfaction
Sep 24, 2010 | ASUS Computers & Internet
Acer travelmate 4010 model zl1 ; pxe-e61: media test failure , check cable; system won't boot; operating system not found
clean filesystem with a scan disc if it isnt a mother board failure reinstall OS from external drive
Sep 06, 2010 | Acer TravelMate 4010 Notebook
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
I GOT THIS MESSAGE TODAY PXE-E61 MEDIA TEST FAILURE CHECK CABLE WHEN I TRIED TO BOOT MY ACER ASPIRE 5630 THIS MORNING. IS THERE A QUICK FIX FOR THIS? EXITING BROADCOM PXE ROM OPERATING SYSTEM NOT FOUND
It is trying to bbot up using network boot because it cannot find OS on the hard drive, you can turn off the network in the BIOS setup page, but more likely you have problem with the hard drive or the OS is corrupted.
Nov 04, 2009 | Acer Aspire 5630 Notebook
Operating System not found PXE-E61 Media Test Failure IBM T42
Some BIOS allows for a hard drive diags. try it to test the hard drive, if ther is no such utility you need to test the hard drive anoter way.
Basically either the hard disk controller has failed or the hard drive is faulty. In most cases the hard drive is dead.
To check if the hard drive is OK, remove the hard drive and attach it to a USB hard drive adapter then plug it into a working computer's USB port. If the computer sees it as an external drive and you can view the contents of the external drive then the hard drive is OK.
Mar 21, 2009 | IBM ThinkPad T30 2366 Notebook
Media test failure
Do you have the PXE error?
The media failure is in the boot sequence, on the toshiba press F12 on boot to change boot priority, select cd/dvd or hard drive, or to preclude from happening, press F2 on boot enter BIOS, select Boot options make sure to set priority as cd/dvd, then hard drive, then network or disable network boot. network booting causes media failure.
Mar 20, 2008 | Computers & Internet
Dell Inspiron 1501 Laptop Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
