Question about Sony CDP-CE275 5-Disc CD Changer
Having a problem with a sony cdp-ce275 5 discs are being checked and lifted but after goes through cycle it reads 'no disc'
Discs are not spinning
  • Sony Master
  • 1,267 Answers
These units have optical sensors in them and the pickup assembly may have gone out of alignment. The Spindle platter can sneek down and put the CD out of range of the focus. I worked on a lot of these in a refurbishing business. They are usually not fixed at service shops due top the high cost to repair such and item.
Posted on Dec 11, 2012
SOURCE: player reads no disc
make sure you are putting them in correctly
Posted on Jan 27, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony CDP-C235 CD Changer Dirty Laser Problem
Please replace optical block (laser) of CDP-C235.
It is available in Part Store.
Posted on Jan 15, 2009
smarthome2
  • 1114 Answers
SOURCE: Sony CDP-C225 will not read or play cd's
Try running a "Laser Lens Cleaner" thru it, preferrably one that uses fluid. You can purchase one at just about any retail store for 15-20. Good to have and great preventative maintanance. If that does not work, you need a new transport, they do not repair or align lasers. Too expensive. The replacement is 100-150 with labor and a new one is under 200. My suggestion would be if the cleaner does not work replace it and keep the new one clean. CD/DVD/PC etc. all can and should be cleaned 3 or 4 times a year. Best preventative maintanance you can do. Hope this helps
Posted on Jun 24, 2009
  • 1039 Answers
SOURCE: On my Sony CDP-C910 CD changer I get message
Spin motor or pickup is bad. Replace the unit. Expence to repair for this age machine not practical.
Posted on Nov 01, 2009
smarthome2
  • 1114 Answers
SOURCE: disc(s) jammed in sony 5-disc player--eject won't work
There are 6 or 7 phillips head screws that keep the top on; remove them and pop the top. This will give you access to all CD's. Remove them all, then plug the unit back in and press the open close button and check for normal operation. If it still wont open, it's broken a gear and needs to be serviced. You may consider replacement of the unit if inoperative, the replacement model is priced at $129.00 and a repair would probably cost the same if not more. If you need further help, post a comment and I can help you further.
Posted on Dec 22, 2009
Sony cdp c500 won't read CDs. Just cycles through and then says 'no disk'.
You can try picking up a cleaning kit for the reader. If that does not work you can replace the reader itself. You will be able to find the replacement online.
Dec 21, 2014 | Sony Cdp-c500 5 Disc Cd Changer Dual D/a...
What is wrong when jvc cd changer reads "no disc" even when disc is available?
I too have this problem with my Pioneer PD-X77M. It will not recognize the CD in the case & goes through all six saying NO Disc.
Jun 13, 2014 | Sony CDP-CX350 300-Disc CD Changer
Compact Disc Player CDP-CX300 not reading discs
Probably have to get the laser replaced as long as all the mechanics are working to load the disc.
Jan 02, 2013 | Sony CDP-CX300 CD Player
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
My Sony CDP-C910 cycles through CDs, never playing
when its cycled thru them .,does it stop?does it show them on the screen with a lit circle?are they normal cds.can you select one cd to play?hold the eject button in for about 5 seconds,see if that resets it
Jul 11, 2010 | Sony CDP-C910 10-Disc CD Changer
Jan 15, 2009 | Sony CDP-CE375 5-Disc CD Changer
Player reads no disc
try to clean the lens use coton and water. do not use cleaning disc.
Sep 17, 2007 | Sony MegaStorage CDP-CX355 300-Disc CD...
Sony CDP-CE275 5-Disc CD Changer Logo
83 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
