Question about Bosch Integra® 500 SHX46A0 Dishwasher
My Bosch Model #SHX46A02UC/36 will not drain after the cycle is has ran
  • 1462 Answers
SOURCE: Bosch built in dishwasher model # SHX46A02UC
sounds as tho you have a foreign object stuck in the drain pump. only solution is to remove drain pump and check
Posted on Jun 25, 2008
Krazytech
  • 725 Answers
SOURCE: Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Posted on Aug 21, 2008
  • 21 Answers
SOURCE: Bosch dishwasher model shx33a can't figure out how to just drain without running the whole cycle...HELP
HIT THE CANCEL DRAIN BUTTONS 2 BUTTONS TOGETHER THIS WILL RESET AND DRAIN ANY STANDING WATER
Posted on Jul 20, 2009
  • 39 Answers
SOURCE: Bosch dishwasher continues to run (Model SHX46A02UC)
searched oother sites. some report a circuit board problem where one of the solder joints overheated and burned out of contact. check yours and repair/replace if that is the problem.
if not at least you can rule it out.
Posted on Oct 29, 2009
ginko
  • 19396 Answers
SOURCE: SHX46A02UC dishwasher will not complete cycle.
Test the door switch and its wiring. The dishwasher is supposed to stop when door is open.
About drain pump, check the pressure switch and eventually replace it(pressure is water level, this is not the float, that is usually overfill-if there is no pressure switch, check float). That is the device that detects if drain is over, stopping the drain pump.
Posted on Sep 15, 2010
How to operate correct buttons on shx46a02uc/14
Here is the manual: http://wwashing.com/2013/10/06/bosch-ecel-washing-machine-instructions/
Jun 16, 2014 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher model SHU66C06 doesn't enter wash cycle
this sounds like flow sensor failure,it it fails machine will either not fill up or fill and drain without washing its a cheap part to replace and is fitted downstream of inlet valve behind l/h/s side panel either attached to inle hose or heat exchanger.
Mar 03, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHX33A05UC/36 dishwasher seems to run for hours to do a load of dishes. Checked water temperature, drain and hose and all is clean. The rinse and hold cycle times out correctly. Is it a timer or...
No, the problem in not the unit, it is programed to run up to 3-3 1/2 hours for a single cycle. You can select quick wash to shorten this time down, but this is not a problem with the unit. It wants to assure you have clean dishes and hot enough water to complete the program.
In testing one a few days ago, I ran into this same problem, I reread the time charts and cycles and found this to be normal for this manufacture.
I hope this answered your question.
Aug 13, 2011 | Dishwashers
This is too common a problem with these units. I have written a guide to help folks out with it. Find it here.
Jul 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Bosch SHX46A02UC-21
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Jun 24, 2008 | Bosch Dishwashers
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Bosch Integra® 500 SHX46A0 Dishwasher Logo
69 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
