Question about Milwaukee 2401-22 12V Lithium-Ion Sub-Compact Driver Kit--When You Buy Two M12 Kits, Get a FREE M12 Impact Driver by Mail-In Rebate!
My brushless drill will not work, battery charged, light comes on, drill doesn't work
Was working with the drill, worked perfectly all day, next morning, the light would come on the led by the trigger, but the drill will not operate. Battery is fully charged, only 6 months old.
2 Suggested Answers
SOURCE: Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Posted on Dec 15, 2009
Hi I have a Dewalt 18 volt impact driver (DCF 886 brushless) I've had it for just over 12 months and now it is no longer working properly.
I would bring it to an authorized service center and ask for warranty - there are not individual replacement parts, all the electronics come as one assembly, and unfortunately the brushless controllers are very expensive making the tool not worth repairing.
Jan 05, 2017 | Dewalt Drills
My brushless Makita drill driver just stopped. It wasn't hot and the battery is fine. I clicked a fully charged battery into it and nothing. But when I put that battery into another drill nothing.
If you are ABSOLUTELY certain that the batteries are good then the only other culprit has to be the switch that feeds power to brushless motor. Also check battery contacts for corrosion.
May 26, 2016 | Makita Drills
Makita battery wont keep charge
Given the problems with Makita Li-ion batteries there are 2 likely reasons, you have a faulty charger or both batteries are faulty, the best option is to find another charger to try your batteries on and see if they charge, depending on the age of the drill you may be able to get the batteries or charger replaced by Makita, a lot of them have been replaced out of the warranty period because they are known to fail prematurely, take the faulty item back to the place of purchase with you invoice and put the pressure on for replacement
May 03, 2014 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Porter-Cable battery charger model #8605
go to www.dewaltservicenet.com and enter the model number of your drill. It will get you to the parts breakdown and will tell you if there is a charger available from the factory. Or call 1-800-433-9258 1-800-4DEWALT. stanley black and decker owns all of them so yes that's the right place!
Jan 02, 2013 | Porter Cable 19.2V Drill Kit
Dewalt dc825 does not run
Look online from there site.Need new one.
Aug 12, 2012 | Dewalt 18v Cordless Impact Screw Driver...
I have a Makita BHP454 cordless drill and lately when I pull the trigger it won't do anything. The lights work but it doesn't move. I have to give it a hit to make it work again.. What would b the...
The first thing to check is the battery: is it fully charged, are the contacts in good condidtion and do they make good contact with the contacts on the switch.
Next thing to check is the brushes. Remove the rear cover and check the brushes and springs that hold them down on the armature. If the brushes are worn to where they dont' make good contact or the springs are not holding them down with enough pressure they won't make good contact and sometimes a good hit will make them touch enough to work again. The brush part number is CB-440, if the springs are bad you have to replave the whold brush holder, part number 638614-1.
Feb 14, 2012 | Makita Drills
Computer working perfectly fine one day, the next computer won't turn on for no apparent reason. when switching the power button on, computer begins to boot up for a brief moment, then automatically...
It's probably your logic board. One thing you can try that may help you out is to take out the battery (if you can) and press and hold the power button for 10 seconds. If it's a capacitor problem on the board that should discharge it. If that doesn't work then you should probably try to turn on the computer while holding CMD + Option + P + R to reset the PRAM. If that doesn't work then you're probably going to have to seek professional help.
Aug 04, 2011 | Apple Computers & Internet
Battery not charging. Orange and Green light on charger. 18V Plus one system
The air holes on the bottom of the batteries are there for the battery to vent. Downside is, these vents can also allow moisture to get in and prevent contacts from letting the battery charge and causing the "defective" display on the charger.
I work on pool and spa equipment and I had dropped my batteries in a small puddle of water where I was working, both went dead immediately and both showed "defective" on the charger even after drying them out for a few days.
Tried using a can of air and gave each of the vent holes several shots... The batteries charged and are now working perfectly.
I'm sure even overnight condensation could be the culprit for a charger to display "Defective"
Jun 24, 2011 | Ryobi Multi-Volt Battery Charger
I have an 18volt Dewalt XRP 1/2 inch drill. The drill has been working perfectly up until this morning when I took it froms its case. I was using it the evening before to screw in some 2 inch screws into...
Check electrical contacts in drill body where battery connects. Check wiring inside the drill, trigger and check also brushes. You do not have to invest 329, you can buy "body only" machine for few bucks and reuse your charger and battery packs. Juraj
Oct 20, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Milwaukee 2401-22 12V Lithium-Ion Sub-Compact Driver Kit--When You Buy Two M12 Kits, Get a FREE M12 Impact Driver by Mail-In Rebate!  Logo
Top Milwaukee Tools & Hardware - Others Experts
Joseph Mueller
Joseph Mueller
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Milwaukee Tool and Hardware - Other Expert? Answer questions, earn points and help others
