Question about Panasonic Toughbook 19 Laptop Convertible Tablet
The enter key doesnt work
When I push the Enter key, nothing happens
  • Panasonic Master
  • 27,725 Answers
What program are you trying to access ?
The enter key is usually used for DOS command prompt.
or when typing in passwords to enter certain programs or computers and email accounts
click stat type into search cmd press enter a black screen should open
It might be a problem with the actual enter key on your keyboard.
Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol to get it sparkling clean hope this helps
Posted on Dec 10, 2012
Enter key doesnt work
well i understand it can be a bothersome issue to not be able to press enter but we have to identify the reason behind it , it could be the circuit is burnt so probably you will have to change the keyboard but as first try and see if the Enter key is functioning in the DOS screen , not in an operating system . press F10 to go to bios screen and therefore go to exit and press Enter , if it doesn't work just press cntl + alt + del and it will restart but with this it will show that the circuit is burnt and you have to replace the keyboard.
Jan 22, 2013 | HP Pavilion dv6-1030us Notebook
My daughters laptop went blank. she doesnt know what happen. when i turn it on it gives me a list of things or options and when i press. start normally it does nothing. what shoild i do
if one of the options is start windows normally, just push the up/ down arrows to get to it, then press enter and it should go to normal, make sure you push enter, if it doesnt work, turn it off then back on and try it again
Jan 30, 2011 | Coby NBPC1023XPPNK Netbook
I try to write a fraction down on my TI-83 calc. But i dont know how to find that function. When i go to MATH and choose FRAC it doesnt do anything even if i type a number down next to it.
To keep a fraction in fraction format (though reduced) you must enter the numerator, press the Division key, followed by a number (denominator).
If you press ENTER, the fraction will be displayed as a decimal number.
However if you use the sequence [MATH][1:ToFrac] peior to pressing [ENTER] the result will be the irreducible form pf the fraction you entered.
Obviously, if you enter an interger number there will not be any fraction display.
Also, if your "number down next to it" means after the [ToFrac], then it is clear that nothing will happen.
Try what I suggest and see if that works.
Apr 16, 2010 | Texas Instruments TI-84 Plus Silver...
I would really like the unlock code for the original Fate but everytime i buy it it says its invalid. what do i do?
Entering the Keycode but nothing happens and I cannot continue
Key has not been correctly entered. Do not enter any space anywhere in the key.
Delete the full key with BACKSPACE and re-enter. Check for CAPS not being active and always enter the “-“ in between the digit/letter combinations
hope it works:)
Feb 04, 2010 | JoWood Productions Fate for Windows
I have the code but it doesnt unlock radio
make sure the display does not say off-if it does turn key all the way forward without starting the car with the radio on,check it half 45 min or 1hr and it should read code on display -enter code then press cd button,good luck
Oct 05, 2009 | 1994 Mitsubishi 3000GT
Programming scanner
Press prgm, enter code,press enter last repeat for each channel.
Apr 22, 2008 | Uniden BC340CRS Base Scanner
Panasonic Toughbook 19 Laptop Convertible Tablet Logo
207 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
